Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=534&projectId=27
Build statistics:
State: Error
Previous State: Ok
Started at: Mon 17 Dec 2007 20:01:35 -0500
Finished at: Mon 17 Dec 2007 20:30:43 -0500
Total time: 29m 7s
Build Trigger: Schedule
Build Number: 42
Exit code: 0
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.4.2_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_12-b03)
Java HotSpot(TM) Client VM (build 1.4.2_12-b03, mixed mode)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: jdeolive @ Mon 17 Dec 2007 19:56:19 -0500
Comment: changed version numbers to 1.6.0-RC2
Files changed:
/branches/1.6.x/geoserver/community/Issues/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/QueryUsers/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/RESTConfig/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/community-schemas/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/community-schemas/web-c/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/community-schemas/wfs-c/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/hello/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/hello_web/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/kml-ows5/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/modular_ui/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/modular_ui/wicket-sample/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/net.opengis.wcs/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/openplans-authentication/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/preferences/web/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/statusreporter/core/pom.xml ( 8038 )
/branches/1.6.x/geoserver/community/wcs11/pom.xml ( 8038 )
/branches/1.6.x/geoserver/data/pom.xml ( 8038 )
/branches/1.6.x/geoserver/main/pom.xml ( 8038 )
/branches/1.6.x/geoserver/maven/build-configs/pom.xml ( 8038 )
/branches/1.6.x/geoserver/maven/config/pom.xml ( 8038 )
/branches/1.6.x/geoserver/maven/pom.xml ( 8038 )
/branches/1.6.x/geoserver/net.opengis.ows/pom.xml ( 8038 )
/branches/1.6.x/geoserver/net.opengis.wfs/pom.xml ( 8038 )
/branches/1.6.x/geoserver/net.opengis.wfsv/pom.xml ( 8038 )
/branches/1.6.x/geoserver/ows/pom.xml ( 8038 )
/branches/1.6.x/geoserver/platform/pom.xml ( 8038 )
/branches/1.6.x/geoserver/pom.xml ( 8038 )
/branches/1.6.x/geoserver/release/ext-gml.xml ( 8038 )
/branches/1.6.x/geoserver/release/extensions/arcsde/arcsde-readme.txt ( 8038 )
/branches/1.6.x/geoserver/release/extensions/db2/db2-readme.txt ( 8038 )
/branches/1.6.x/geoserver/release/extensions/mysql/mysql-readme.txt ( 8038 )
/branches/1.6.x/geoserver/release/extensions/oracle/oracle-readme.txt ( 8038 )
/branches/1.6.x/geoserver/release/extensions/pyramid/pyramid-readme.txt ( 8038 )
/branches/1.6.x/geoserver/release/extensions/vpf/vpf-readme.txt ( 8038 )
/branches/1.6.x/geoserver/release/geoserver.nsi ( 8038 )
/branches/1.6.x/geoserver/release/pom.xml ( 8038 )
/branches/1.6.x/geoserver/stress/pom.xml ( 8038 )
/branches/1.6.x/geoserver/test/pom.xml ( 8038 )
/branches/1.6.x/geoserver/validation/pom.xml ( 8038 )
/branches/1.6.x/geoserver/wcs/pom.xml ( 8038 )
/branches/1.6.x/geoserver/web/pom.xml ( 8038 )
/branches/1.6.x/geoserver/web/src/main/java/ApplicationResources.properties ( 8038 )
/branches/1.6.x/geoserver/web/src/main/java/ApplicationResources_de.properties ( 8038 )
/branches/1.6.x/geoserver/web/src/main/java/ApplicationResources_es.properties ( 8038 )
/branches/1.6.x/geoserver/web/src/main/java/ApplicationResources_fr.properties ( 8038 )
/branches/1.6.x/geoserver/web/src/main/java/ApplicationResources_ja.properties ( 8038 )
/branches/1.6.x/geoserver/web/src/main/java/ApplicationResources_pt_BR.properties ( 8038 )
/branches/1.6.x/geoserver/web/src/main/java/ApplicationResources_zh_CN.properties ( 8038 )
/branches/1.6.x/geoserver/wfs/pom.xml ( 8038 )
/branches/1.6.x/geoserver/wfsv/pom.xml ( 8038 )
/branches/1.6.x/geoserver/wms/pom.xml ( 8038 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk4
Description: default maven2 buildDefinition
Test Summary:
Tests: 203
Failures: 0
Total time: 311.45502
Build Error:
org.apache.maven.continuum.execution.ContinuumBuildCancelledException: The build was cancelled
at org.apache.maven.continuum.execution.AbstractBuildExecutor.executeShellCommand(AbstractBuildExecutor.java:214)
at org.apache.maven.continuum.execution.maven.m2.MavenTwoBuildExecutor.build(MavenTwoBuildExecutor.java:138)
at org.apache.maven.continuum.core.action.ExecuteBuilderContinuumAction.execute(ExecuteBuilderContinuumAction.java:118)
at org.apache.maven.continuum.buildcontroller.DefaultBuildController.performAction(DefaultBuildController.java:408)
at org.apache.maven.continuum.buildcontroller.DefaultBuildController.build(DefaultBuildController.java:147)
at org.apache.maven.continuum.buildcontroller.BuildProjectTaskExecutor.executeTask(BuildProjectTaskExecutor.java:50)
at org.codehaus.plexus.taskqueue.execution.ThreadedTaskQueueExecutor$ExecutorRunnable$1.run(ThreadedTaskQueueExecutor.java:116)
at edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:442)
at edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:176)
at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:665)
at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:690)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.codehaus.plexus.util.cli.CommandLineException: Error while executing external command, process killed.
at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:164)
at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:89)
at org.apache.maven.continuum.utils.shell.DefaultShellCommandHelper.executeShellCommand(DefaultShellCommandHelper.java:114)
at org.apache.maven.continuum.utils.shell.DefaultShellCommandHelper.executeShellCommand(DefaultShellCommandHelper.java:59)
at org.apache.maven.continuum.execution.AbstractBuildExecutor.executeShellCommand(AbstractBuildExecutor.java:202)
... 11 more
Caused by: java.lang.InterruptedException
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:474)
at java.lang.UNIXProcess.waitFor(UNIXProcess.java:165)
at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:128)
... 15 more
