Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=503&projectId=25
Build statistics:
State: Error
Previous State: Failed
Started at: Mon 17 Dec 2007 09:35:53 -0500
Finished at: Mon 17 Dec 2007 10:05:23 -0500
Total time: 29m 30s
Build Trigger: Schedule
Build Number: 39
Exit code: 0
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.5.0_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Mon 17 Dec 2007 08:57:24 -0500
Comment: Fixing compile errors after deprecated methods where removed from gt2 trunk
Files changed:
/trunk/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/coverage/AscCoverageResponseDelegate.java ( 8026 )
/trunk/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/coverage/GTopo30CoverageResponseDelegate.java ( 8026 )
/trunk/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/coverage/GeoTIFFCoverageResponseDelegate.java ( 8026 )
/trunk/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/coverage/IMGCoverageResponseDelegate.java ( 8026 )
/trunk/geoserver/wms/src/main/java/org/vfny/geoserver/wms/requests/GetLegendGraphicKvpReader.java ( 8026 )
Changed: aaime @ Mon 17 Dec 2007 08:59:41 -0500
Comment: GEOS-1617, Reprojected FeatureCollection bounds are incorrect when datastore is Postgis
Files changed:
/trunk/geoserver/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureSource.java ( 8027 )
/trunk/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureLocking.java ( 8027 )
/trunk/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureSource.java ( 8027 )
/trunk/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureStore.java ( 8027 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk5
Description: default maven2 buildDefinition
Test Summary:
Tests: 205
Failures: 1
Total time: 314.108
Build Error:
org.apache.maven.continuum.execution.ContinuumBuildCancelledException: The build was cancelled
at org.apache.maven.continuum.execution.AbstractBuildExecutor.executeShellCommand(AbstractBuildExecutor.java:214)
at org.apache.maven.continuum.execution.maven.m2.MavenTwoBuildExecutor.build(MavenTwoBuildExecutor.java:138)
at org.apache.maven.continuum.core.action.ExecuteBuilderContinuumAction.execute(ExecuteBuilderContinuumAction.java:118)
at org.apache.maven.continuum.buildcontroller.DefaultBuildController.performAction(DefaultBuildController.java:408)
at org.apache.maven.continuum.buildcontroller.DefaultBuildController.build(DefaultBuildController.java:147)
at org.apache.maven.continuum.buildcontroller.BuildProjectTaskExecutor.executeTask(BuildProjectTaskExecutor.java:50)
at org.codehaus.plexus.taskqueue.execution.ThreadedTaskQueueExecutor$ExecutorRunnable$1.run(ThreadedTaskQueueExecutor.java:116)
at edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:442)
at edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:176)
at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:665)
at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:690)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.codehaus.plexus.util.cli.CommandLineException: Error while executing external command, process killed.
at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:164)
at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:89)
at org.apache.maven.continuum.utils.shell.DefaultShellCommandHelper.executeShellCommand(DefaultShellCommandHelper.java:114)
at org.apache.maven.continuum.utils.shell.DefaultShellCommandHelper.executeShellCommand(DefaultShellCommandHelper.java:59)
at org.apache.maven.continuum.execution.AbstractBuildExecutor.executeShellCommand(AbstractBuildExecutor.java:202)
... 11 more
Caused by: java.lang.InterruptedException
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:474)
at java.lang.UNIXProcess.waitFor(UNIXProcess.java:165)
at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:128)
... 15 more
Test Failures:
ReprojectionTest
testReprojectNullGeometries :
junit.framework.AssertionFailedError
junit.framework.AssertionFailedError: expected:&1& but was:&0&
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.failNotEquals(Assert.java:282)
at junit.framework.Assert.assertEquals(Assert.java:64)
at junit.framework.Assert.assertEquals(Assert.java:201)
at junit.framework.Assert.assertEquals(Assert.java:207)
at org.geoserver.wfs.ReprojectionTest.testReprojectNullGeometries(ReprojectionTest.java:88)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at sun.reflect.GeneratedMethodAccessor101.invoke(Unknown Source)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:138)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:125)
at org.apache.maven.surefire.Surefire.run(Surefire.java:132)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:290)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:818)
