Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=276&projectId=27
Build statistics:
State: Failed
Previous State: Ok
Started at: Thu 6 Dec 2007 05:01:09 -0500
Finished at: Thu 6 Dec 2007 05:05:34 -0500
Total time: 4m 25s
Build Trigger: Schedule
Build Number: 19
Exit code: 1
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.4.2_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_12-b03)
Java HotSpot(TM) Client VM (build 1.4.2_12-b03, mixed mode)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Thu 6 Dec 2007 04:58:08 -0500
Comment: Reformatted by removing the tabs. sigh..
Files changed:
/branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/svg/SVGBatikMapProducer.java ( 7949 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk4
Description: default maven2 buildDefinition
Test Summary:
Tests: 198
Failures: 0
Total time: 193.69797
