Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=399&projectId=27
Build statistics:
State: Failed
Previous State: Ok
Started at: Wed 12 Dec 2007 15:51:26 -0500
Finished at: Wed 12 Dec 2007 15:57:09 -0500
Total time: 5m 42s
Build Trigger: Schedule
Build Number: 32
Exit code: 1
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.4.2_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_12-b03)
Java HotSpot(TM) Client VM (build 1.4.2_12-b03, mixed mode)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Wed 12 Dec 2007 15:29:15 -0500
Comment: Updates for versioned feature collection work
Files changed:
/branches/1.6.x/geoserver/net.opengis.vwfs/META-INF/MANIFEST.MF ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/schemas/wfs/1.1.0/wfsv.xsd ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/AbstractVersionedFeatureType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/DescribeVersionedFeatureTypeType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/DifferenceQueryType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/DocumentRoot.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/GetDiffType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/GetLogType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/GetVersionedFeatureType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/RollbackType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/VersionedDeleteElementType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/VersionedFeatureCollectionType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/VersionedUpdateElementType.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/WfsvFactory.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/WfsvPackage.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/AbstractVersionedFeatureTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/DescribeVersionedFeatureTypeTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/DifferenceQueryTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/DocumentRootImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/GetDiffTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/GetLogTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/GetVersionedFeatureTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/RollbackTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/VersionedDeleteElementTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/VersionedFeatureCollectionTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/VersionedUpdateElementTypeImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/WfsvFactoryImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/impl/WfsvPackageImpl.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/util/WfsvAdapterFactory.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/src/net/opengis/wfsv/util/WfsvSwitch.java ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/wfsv.ecore ( 7988 )
/branches/1.6.x/geoserver/net.opengis.vwfs/wfsv.genmodel ( 7988 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk4
Description: default maven2 buildDefinition
Test Summary:
Tests: 200
Failures: 0
Total time: 355.08997
