[Geoserver-devel] [continuum] BUILD FAILURE: GeoServer JDK5 - GeoServer - Build Def: default maven2 buildDefinition
Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=291&projectId=25
Build statistics:
  State: Failed
  Previous State: Failed
  Started at: Thu 6 Dec 2007 10:35:34 -0500
  Finished at: Thu 6 Dec 2007 10:39:00 -0500
  Total time: 3m 25s
  Build Trigger: Schedule
  Build Number: 30
  Exit code: 1
  Building machine hostname: traffic.openplans.org
  Operating system : Linux(unknown)
  Java Home version : java version "1.5.0_12"
          Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
          Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
          Builder version :
          Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Thu 6 Dec 2007 10:32:54 -0500
Comment: Fixed compile error due to latest changes in geoapi...
Files changed:
  /trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/TransactionEventType.java ( 7954 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk5
Description: default maven2 buildDefinition
Test Summary:
Tests: 199
Failures: 42
Total time: 172.28903
Test Failures:
GetFeatureTest
    testGet :
  junit.framework.ComparisonFailure
  junit.framework.ComparisonFailure: expected:&wfs:FeatureCollection& but was:&ServiceExceptionReport&
  at junit.framework.Assert.assertEquals(Assert.java:81)
  at junit.framework.Assert.assertEquals(Assert.java:87)
  at org.geoserver.wfs.GetFeatureTest.testGetFifteenAll(GetFeatureTest.java:23)
  at org.geoserver.wfs.GetFeatureTest.testGet(GetFeatureTest.java:10)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:138)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:125)
  at org.apache.maven.surefire.Surefire.run(Surefire.java:132)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:290)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:818)
    testGetPropertyNameEmpty :
  at org.geoserver.wfs.GetFeatureTest.testGetPropertyNameEmpty(GetFeatureTest.java:14)
    testGetPropertyNameStar :
  at org.geoserver.wfs.GetFeatureTest.testGetPropertyNameStar(GetFeatureTest.java:18)
    testPost :
  at org.geoserver.wfs.GetFeatureTest.testPost(GetFeatureTest.java:50)
    testPostWithFilter :
  at org.geoserver.wfs.GetFeatureTest.testPostWithFilter(GetFeatureTest.java:76)
  GetFeatureWithLockTest
    testUpdateLockedFeatureWithLockId :
  at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithLockId(GetFeatureWithLockTest.java:21)
    testUpdateLockedFeatureWithoutLockId :
  at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:82)
    testGetFeatureWithLockReleaseActionSome :
  java.lang.NullPointerException
  $failure.exception
  LockFeatureTest
    testLockActionSomeAlreadyLocked :
  at org.geoserver.wfs.LockFeatureTest.testLockActionSomeAlreadyLocked(LockFeatureTest.java:20)
    testDeleteWithoutLockId :
  at org.geoserver.wfs.LockFeatureTest.testDeleteWithoutLockId(LockFeatureTest.java:74)
    testUpdateWithLockId :
  at org.geoserver.wfs.LockFeatureTest.testUpdateWithLockId(LockFeatureTest.java:127)
  TransactionTest
    testInsert1 :
  junit.framework.ComparisonFailure: expected:&wfs:TransactionResponse& but was:&ows:ExceptionReport&
  at org.geoserver.wfs.v1_1.TransactionTest.testInsert1(TransactionTest.java:90)
    testInsertWithNoSRS :
  junit.framework.AssertionFailedError
  at junit.framework.Assert.fail(Assert.java:47)
  at junit.framework.Assert.assertTrue(Assert.java:20)
  at junit.framework.Assert.assertNotNull(Assert.java:220)
  at junit.framework.Assert.assertNotNull(Assert.java:213)
  at org.geoserver.wfs.v1_1.TransactionTest.testInsertWithNoSRS(TransactionTest.java:124)
    testInsertWithSRS :
  at org.geoserver.wfs.v1_1.TransactionTest.testInsertWithSRS(TransactionTest.java:180)
    testInsertWithGMLProperties :
  junit.framework.AssertionFailedError: expected:&2& but was:&0&
  at junit.framework.Assert.failNotEquals(Assert.java:282)
  at junit.framework.Assert.assertEquals(Assert.java:64)
  at junit.framework.Assert.assertEquals(Assert.java:201)
  at junit.framework.Assert.assertEquals(Assert.java:207)
  at org.geoserver.wfs.v1_1.TransactionTest.testInsertWithGMLProperties(TransactionTest.java:225)
    testUpdateWithGMLProperties :
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithGMLProperties(TransactionTest.java:306)
    testUpdateNoSRS :
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdate(TransactionTest.java:495)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateNoSRS(TransactionTest.java:462)
  GetFeatureTest
    testGet :
  junit.framework.ComparisonFailure: expected:&wfs:FeatureCollection& but was:&ows:ExceptionReport&
  at org.geoserver.wfs.v1_1.GetFeatureTest.testGetFifteenAll(GetFeatureTest.java:42)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testGet(GetFeatureTest.java:29)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testGetPropertyNameEmpty(GetFeatureTest.java:33)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testGetPropertyNameStar(GetFeatureTest.java:37)
    testPost :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testPost(GetFeatureTest.java:66)
    testPostFormEncoded :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testPostFormEncoded(GetFeatureTest.java:84)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithFilter(GetFeatureTest.java:107)
    testPostWithBboxFilter :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithBboxFilter(GetFeatureTest.java:141)
    testPostWithFailingUrnBboxFilter :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithFailingUrnBboxFilter(GetFeatureTest.java:170)
    testPostWithMatchingUrnBboxFilter :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithMatchingUrnBboxFilter(GetFeatureTest.java:197)
    testResultTypeHitsGet :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testResultTypeHitsGet(GetFeatureTest.java:204)
    testResultTypeHitsPost :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testResultTypeHitsPost(GetFeatureTest.java:225)
    testWithSRS :
  junit.framework.AssertionFailedError: expected:&1& but was:&0&
  at org.geoserver.wfs.v1_1.GetFeatureTest.testWithSRS(GetFeatureTest.java:241)
    testWithSillyLiteral :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testWithSillyLiteral(GetFeatureTest.java:258)
    testWithGmlObjectId :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testWithGmlObjectId(GetFeatureTest.java:270)
    testPostWithBoundsEnabled :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithBoundsEnabled(GetFeatureTest.java:308)
    testAfterFeatureTypeAdded :
  junit.framework.ComparisonFailure: expected:&FeatureCollection& but was:&ExceptionReport&
  at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:342)
    testWithGMLProperties :
  at org.geoserver.wfs.v1_1.GetFeatureTest.testWithGMLProperties(GetFeatureTest.java:348)
    test :
  at org.geoserver.wfs.v1_1.GetFeatureWithLockTest.test(GetFeatureWithLockTest.java:20)
  TransactionTest
    testUpdate :
  at org.geoserver.wfs.TransactionTest.testUpdate(TransactionTest.java:110)
  at sun.reflect.GeneratedMethodAccessor99.invoke(Unknown Source)
    testDelete :
  at org.geoserver.wfs.TransactionTest.testDelete(TransactionTest.java:27)
    testInsert :
  at org.geoserver.wfs.TransactionTest.testInsert(TransactionTest.java:68)
  GMLOutputFormatTest
    testGML2 :
  at org.geoserver.wfs.xml.GMLOutputFormatTest.testGML2(GMLOutputFormatTest.java:21)
    testGML3 :
  at org.geoserver.wfs.xml.GMLOutputFormatTest.testGML3(GMLOutputFormatTest.java:60)
  TransactionListenerTest
    testUpdate :
  at org.geoserver.wfs.TransactionListenerTest.testUpdate(TransactionListenerTest.java:101)
    testDelete :
  at org.geoserver.wfs.TransactionListenerTest.testDelete(TransactionListenerTest.java:50)
    testInsert :
  at org.geoserver.wfs.TransactionListenerTest.testInsert(TransactionListenerTest.java:77)
