Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=292&projectId=25
Build statistics:
State: Failed
Previous State: Failed
Started at: Thu 6 Dec 2007 10:46:59 -0500
Finished at: Thu 6 Dec 2007 10:50:09 -0500
Total time: 3m 9s
Build Trigger: Schedule
Build Number: 30
Exit code: 1
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.5.0_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Thu 6 Dec 2007 10:42:59 -0500
Comment: First fix for GEOS-1578, PROXY_BASE_URL configuration seems to only work part way
Files changed:
/trunk/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/WCSCapabilitiesResponse.java ( 7955 )
/trunk/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/WCSCapsTransformer.java ( 7955 )
/trunk/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/servlets/Capabilities.java ( 7955 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk5
Description: default maven2 buildDefinition
Test Summary:
Tests: 199
Failures: 42
Total time: 171.53102
Test Failures:
GetFeatureTest
testGet :
junit.framework.ComparisonFailure
junit.framework.ComparisonFailure: expected:&wfs:FeatureCollection& but was:&ServiceExceptionReport&
at junit.framework.Assert.assertEquals(Assert.java:81)
at junit.framework.Assert.assertEquals(Assert.java:87)
at org.geoserver.wfs.GetFeatureTest.testGetFifteenAll(GetFeatureTest.java:23)
at org.geoserver.wfs.GetFeatureTest.testGet(GetFeatureTest.java:10)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:138)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:125)
at org.apache.maven.surefire.Surefire.run(Surefire.java:132)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:290)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:818)
testGetPropertyNameEmpty :
at org.geoserver.wfs.GetFeatureTest.testGetPropertyNameEmpty(GetFeatureTest.java:14)
testGetPropertyNameStar :
at org.geoserver.wfs.GetFeatureTest.testGetPropertyNameStar(GetFeatureTest.java:18)
testPost :
at org.geoserver.wfs.GetFeatureTest.testPost(GetFeatureTest.java:50)
testPostWithFilter :
at org.geoserver.wfs.GetFeatureTest.testPostWithFilter(GetFeatureTest.java:76)
GetFeatureWithLockTest
testUpdateLockedFeatureWithLockId :
at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithLockId(GetFeatureWithLockTest.java:21)
testUpdateLockedFeatureWithoutLockId :
at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:82)
testGetFeatureWithLockReleaseActionSome :
java.lang.NullPointerException
$failure.exception
LockFeatureTest
testLockActionSomeAlreadyLocked :
at org.geoserver.wfs.LockFeatureTest.testLockActionSomeAlreadyLocked(LockFeatureTest.java:20)
testDeleteWithoutLockId :
at org.geoserver.wfs.LockFeatureTest.testDeleteWithoutLockId(LockFeatureTest.java:74)
testUpdateWithLockId :
at org.geoserver.wfs.LockFeatureTest.testUpdateWithLockId(LockFeatureTest.java:127)
TransactionTest
testInsert1 :
junit.framework.ComparisonFailure: expected:&wfs:TransactionResponse& but was:&ows:ExceptionReport&
at org.geoserver.wfs.v1_1.TransactionTest.testInsert1(TransactionTest.java:90)
testInsertWithNoSRS :
junit.framework.AssertionFailedError
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.assertTrue(Assert.java:20)
at junit.framework.Assert.assertNotNull(Assert.java:220)
at junit.framework.Assert.assertNotNull(Assert.java:213)
at org.geoserver.wfs.v1_1.TransactionTest.testInsertWithNoSRS(TransactionTest.java:124)
testInsertWithSRS :
at org.geoserver.wfs.v1_1.TransactionTest.testInsertWithSRS(TransactionTest.java:180)
testInsertWithGMLProperties :
junit.framework.AssertionFailedError: expected:&2& but was:&0&
at junit.framework.Assert.failNotEquals(Assert.java:282)
at junit.framework.Assert.assertEquals(Assert.java:64)
at junit.framework.Assert.assertEquals(Assert.java:201)
at junit.framework.Assert.assertEquals(Assert.java:207)
at org.geoserver.wfs.v1_1.TransactionTest.testInsertWithGMLProperties(TransactionTest.java:225)
testUpdateWithGMLProperties :
at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithGMLProperties(TransactionTest.java:306)
testUpdateNoSRS :
at org.geoserver.wfs.v1_1.TransactionTest.testUpdate(TransactionTest.java:495)
at org.geoserver.wfs.v1_1.TransactionTest.testUpdateNoSRS(TransactionTest.java:462)
GetFeatureTest
testGet :
junit.framework.ComparisonFailure: expected:&wfs:FeatureCollection& but was:&ows:ExceptionReport&
at org.geoserver.wfs.v1_1.GetFeatureTest.testGetFifteenAll(GetFeatureTest.java:42)
at org.geoserver.wfs.v1_1.GetFeatureTest.testGet(GetFeatureTest.java:29)
at org.geoserver.wfs.v1_1.GetFeatureTest.testGetPropertyNameEmpty(GetFeatureTest.java:33)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585)
at org.geoserver.wfs.v1_1.GetFeatureTest.testGetPropertyNameStar(GetFeatureTest.java:37)
testPost :
at org.geoserver.wfs.v1_1.GetFeatureTest.testPost(GetFeatureTest.java:66)
testPostFormEncoded :
at org.geoserver.wfs.v1_1.GetFeatureTest.testPostFormEncoded(GetFeatureTest.java:84)
at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithFilter(GetFeatureTest.java:107)
testPostWithBboxFilter :
at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithBboxFilter(GetFeatureTest.java:141)
testPostWithFailingUrnBboxFilter :
at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithFailingUrnBboxFilter(GetFeatureTest.java:170)
testPostWithMatchingUrnBboxFilter :
at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithMatchingUrnBboxFilter(GetFeatureTest.java:197)
testResultTypeHitsGet :
at org.geoserver.wfs.v1_1.GetFeatureTest.testResultTypeHitsGet(GetFeatureTest.java:204)
testResultTypeHitsPost :
at org.geoserver.wfs.v1_1.GetFeatureTest.testResultTypeHitsPost(GetFeatureTest.java:225)
testWithSRS :
junit.framework.AssertionFailedError: expected:&1& but was:&0&
at org.geoserver.wfs.v1_1.GetFeatureTest.testWithSRS(GetFeatureTest.java:241)
testWithSillyLiteral :
at org.geoserver.wfs.v1_1.GetFeatureTest.testWithSillyLiteral(GetFeatureTest.java:258)
testWithGmlObjectId :
at org.geoserver.wfs.v1_1.GetFeatureTest.testWithGmlObjectId(GetFeatureTest.java:270)
testPostWithBoundsEnabled :
at org.geoserver.wfs.v1_1.GetFeatureTest.testPostWithBoundsEnabled(GetFeatureTest.java:308)
testAfterFeatureTypeAdded :
junit.framework.ComparisonFailure: expected:&FeatureCollection& but was:&ExceptionReport&
at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:342)
testWithGMLProperties :
at org.geoserver.wfs.v1_1.GetFeatureTest.testWithGMLProperties(GetFeatureTest.java:348)
test :
at org.geoserver.wfs.v1_1.GetFeatureWithLockTest.test(GetFeatureWithLockTest.java:20)
TransactionTest
testUpdate :
at org.geoserver.wfs.TransactionTest.testUpdate(TransactionTest.java:110)
at sun.reflect.GeneratedMethodAccessor99.invoke(Unknown Source)
testDelete :
at org.geoserver.wfs.TransactionTest.testDelete(TransactionTest.java:27)
testInsert :
at org.geoserver.wfs.TransactionTest.testInsert(TransactionTest.java:68)
GMLOutputFormatTest
testGML2 :
at org.geoserver.wfs.xml.GMLOutputFormatTest.testGML2(GMLOutputFormatTest.java:21)
testGML3 :
at org.geoserver.wfs.xml.GMLOutputFormatTest.testGML3(GMLOutputFormatTest.java:60)
TransactionListenerTest
testUpdate :
at org.geoserver.wfs.TransactionListenerTest.testUpdate(TransactionListenerTest.java:101)
testDelete :
at org.geoserver.wfs.TransactionListenerTest.testDelete(TransactionListenerTest.java:50)
testInsert :
at org.geoserver.wfs.TransactionListenerTest.testInsert(TransactionListenerTest.java:77)
