Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=377&projectId=25
Build statistics:
State: Failed
Previous State: Ok
Started at: Wed 12 Dec 2007 11:19:49 -0500
Finished at: Wed 12 Dec 2007 11:21:29 -0500
Total time: 1m 40s
Build Trigger: Schedule
Build Number: 36
Exit code: 1
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.5.0_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: jdeolive @ Wed 12 Dec 2007 11:18:52 -0500
Comment: GEOS-1558, injecting application schema namespaces for request parsing
Files changed:
/trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/WFSConfiguration.java ( 7975 )
/trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/WfsXmlReader.java ( 7975 )
/trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WFSConfiguration.java ( 7975 )
/trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WfsXmlReader.java ( 7975 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk5
Description: default maven2 buildDefinition
Test Summary:
Tests: 81
Failures: 0
Total time: 98.699
