http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=109&projectId=7
This one I cannot reproduce on my box... is there anyone that can?
yes i can.
Andrea-------------------------------------------------------------------------
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:4007,471ccddd96433327367457!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
If I add a dependency on gt2-wfs with a "test" scope it works ok. There
must be some online tests or something that use gt wfs client?
Justin Deoliveira
Justin Deoliveira ha scritto:
yes i can.
Yes and no. I had the problem of centralizing some bits of code to test
if sigma was up an running in order to run the tests regarging REMOTE_OWS_URL/TYPE (component wms).
Now, I need that code in both the GetMapKvpReaderTest, KMLTest and GetMapTest. The only common superclass of those is GeoServerTestSupport,
so I reluctantly pushed that code there and added a test dependency
onto wfs datastore in main.
I still fail to see why the problem triggers in WFS, since I can see
no code that may trigger the _usage_ of the WFSDataStore (you have
to call GeoServerTestSupport.isRemoteStatesAvailable() in order
to really need the wfs datastore).
Apparently maven is doing some strange reflection stuff that trigger
the need for it.
Solutions I can see:
* merge KvpRequestReaderTestSupport back into GeoServerTestSupport, this
would allow me to have all tests in wms module extend WMSTestSupport
and thus move the REMOTE_OWS_stuff related code there.
Alternatively, move the only method in KvpRequestReaderTestSupport in
an utility class.
* add a dependency to the wfs module... not too nice thought, the
same would have to be done for all other modules depending on
GeoServerTestSupport...
* find out why accessing the list of declared method requires the
wfs datastore around...
Ideas?
Oh, I could also roll out a utility class that does the check
with a static method. That is probably the less invasive solution.
I'm going to adopt this one if nobody tells me not to in the
next 30 minutes (my work day is about to end, I cannot leave
the build broken)
Yeah... I like this approach a bit better. +1
the build broken)
Andrea!DSPAM:4007,471cda85135554901796417!
Justin Deoliveira
