[Geoserver-devel] [continuum] BUILD SUCCESSFUL: GeoServer JDK4 - GeoServer 1.6.x - Build Def: default maven2 buildDefinition
Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=236&projectId=27
Build statistics:
  State: Ok
  Previous State: Building
  Started at: Wed 5 Dec 2007 11:53:01 -0500
  Finished at: Wed 5 Dec 2007 12:04:31 -0500
  Total time: 11m 30s
  Build Trigger: Schedule
  Build Number: 17
  Exit code: 0
  Building machine hostname: traffic.openplans.org
  Operating system : Linux(unknown)
  Java Home version : java version "1.4.2_12"
          Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_12-b03)
          Java HotSpot(TM) Client VM (build 1.4.2_12-b03, mixed mode)
          Builder version :
          Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Wed 28 Nov 2007 10:31:27 -0500
Comment: GEOS-1557 KML encoder keeps on encoding even if the connection is closed mid flight by the client
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/applicationContext.xml ( 7880 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5MapProducerFactory.java ( 7880 )
  /branches/1.6.x/geoserver/web/pom.xml ( 7880 )
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLVectorTransformer.java ( 7880 )
Changed: aaime @ Wed 28 Nov 2007 10:34:52 -0500
Comment: Whoops, removing dependency introduced by mistake
Files changed:
  /branches/1.6.x/geoserver/web/pom.xml ( 7881 )
Changed: aaime @ Wed 28 Nov 2007 11:41:42 -0500
Comment: GEOS-1494 Update schemaData output to new ExtendedData proposal on kml-ows5 output
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5VectorTransformer.java ( 7889 )
Changed: aaime @ Thu 29 Nov 2007 09:24:25 -0500
Comment: GEOS-1496 User 'format_options' to control modules of KML output
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5GeometryTransformer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5MapProducer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5Transformer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5VectorTransformer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java ( 7898 )
Changed: aaime @ Fri 30 Nov 2007 05:09:16 -0500
Comment: GEOS-1563, unclear problem in getcapabilities response
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/helpers/WMSCapsTransformer.java ( 7905 )
Changed: aaime @ Fri 30 Nov 2007 05:15:51 -0500
Comment: GEOS-1561, kml-ows5 build issues
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/pom.xml ( 7907 )
Changed: aaime @ Tue 4 Dec 2007 10:28:15 -0500
Comment: GEOS-1541 Add listener to shapefile renderer so that rendering errors are reported at FINE logging level
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/DefaultRasterMapProducer.java ( 7925 )
Changed: aaime @ Tue 4 Dec 2007 10:31:16 -0500
Comment: GEOS-1571, Inconsistency between scale computed by GeoServer and OL map preview
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/openlayers/OpenLayersMapTemplate.ftl ( 7927 )
Changed: aaime @ Tue 4 Dec 2007 13:05:50 -0500
Comment: Improving TransactionListener and adding support methods to GeoServerTestSupport for custom spring files
Files changed:
  /branches/1.6.x/geoserver/main/src/test/java/org/geoserver/test/GeoServerTestSupport.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/DeleteElementHandler.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/InsertElementHandler.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/TransactionEvent.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/UpdateElementHandler.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTest.java (from /trunk/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTest.java:7930) ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTestContext.xml (from /trunk/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTestContext.xml:7930) ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTester.java (from /trunk/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTester.java:7930) ( 7931 )
  /branches/1.6.x/geoserver/wfsv/src/main/java/org/geoserver/wfsv/RollbackElementHandler.java ( 7931 )
Changed: aaime @ Tue 4 Dec 2007 14:21:10 -0500
Comment: GEOS-1568, Metatile cache expiry should be linked to config reload and transaction plugins
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/applicationContext.xml ( 7936 )
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/metatile/MetatileMapProducer.java ( 7936 )
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/metatile/QuickTileCache.java ( 7936 )
Changed: aaime @ Wed 5 Dec 2007 10:06:07 -0500
Comment: GEOS-1581, WCS Describe Coverage does not work properly with rotated coverages
Files changed:
  /branches/1.6.x/geoserver/main/src/main/java/org/vfny/geoserver/config/CoverageConfig.java ( 7937 )
  /branches/1.6.x/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java ( 7937 )
  /branches/1.6.x/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigWriter.java ( 7937 )
  /branches/1.6.x/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/DescribeResponse.java ( 7937 )
Changed: aaime @ Wed 5 Dec 2007 11:07:39 -0500
Comment: Make sure logging switch occurrs as early as possible
Files changed:
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/web.xml ( 7941 )
Changed: aaime @ Wed 5 Dec 2007 11:09:17 -0500
Comment: GEOS 1559 Geoserver (c) should have date and copyright holder's too
Files changed:
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/layouts/mainLayout.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/mapPreview.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/schemaErrors.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/srsList.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/index.jsp ( 7942 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk4
Description: default maven2 buildDefinition
Test Summary:
Tests: 198
Failures: 0
Total time: 397.90204
