[Geoserver-devel] [continuum] BUILD SUCCESSFUL: GeoServer JDK4 - GeoServer 1.6.x - Build Def: default maven2 buildDefinition
Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=281&projectId=27
Build statistics:
  State: Ok
  Previous State: Failed
  Started at: Thu 6 Dec 2007 06:36:49 -0500
  Finished at: Thu 6 Dec 2007 06:47:06 -0500
  Total time: 10m 17s
  Build Trigger: Schedule
  Build Number: 20
  Exit code: 0
  Building machine hostname: traffic.openplans.org
  Operating system : Linux(unknown)
  Java Home version : java version "1.4.2_12"
          Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_12-b03)
          Java HotSpot(TM) Client VM (build 1.4.2_12-b03, mixed mode)
          Builder version :
          Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Thu 6 Dec 2007 06:24:02 -0500
Comment: Upgrading GeoApi since gt2 2.4.x did the same...
Files changed:
  /branches/1.6.x/geoserver/pom.xml ( 7950 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk4
Description: default maven2 buildDefinition
Test Summary:
Tests: 198
Failures: 0
Total time: 317.634
