[Geoserver-devel] [continuum] BUILD SUCCESSFUL: GeoServer JDK4 - GeoServer 1.6.x - Build Def: default maven2 buildDefinition
Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=397&projectId=27
Build statistics:
  State: Ok
  Previous State: Building
  Started at: Wed 12 Dec 2007 15:15:01 -0500
  Finished at: Wed 12 Dec 2007 15:26:02 -0500
  Total time: 11m 0s
  Build Trigger: Schedule
  Build Number: 32
  Exit code: 0
  Building machine hostname: traffic.openplans.org
  Operating system : Linux(unknown)
  Java Home version : java version "1.4.2_12"
          Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_12-b03)
          Java HotSpot(TM) Client VM (build 1.4.2_12-b03, mixed mode)
          Builder version :
          Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Wed 28 Nov 2007 10:31:27 -0500
Comment: GEOS-1557 KML encoder keeps on encoding even if the connection is closed mid flight by the client
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/applicationContext.xml ( 7880 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5MapProducerFactory.java ( 7880 )
  /branches/1.6.x/geoserver/web/pom.xml ( 7880 )
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLVectorTransformer.java ( 7880 )
Changed: aaime @ Wed 28 Nov 2007 10:34:52 -0500
Comment: Whoops, removing dependency introduced by mistake
Files changed:
  /branches/1.6.x/geoserver/web/pom.xml ( 7881 )
Changed: aaime @ Wed 28 Nov 2007 11:41:42 -0500
Comment: GEOS-1494 Update schemaData output to new ExtendedData proposal on kml-ows5 output
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5VectorTransformer.java ( 7889 )
Changed: aaime @ Thu 29 Nov 2007 09:24:25 -0500
Comment: GEOS-1496 User 'format_options' to control modules of KML output
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5GeometryTransformer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5MapProducer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5Transformer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5VectorTransformer.java ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml ( 7898 )
  /branches/1.6.x/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java ( 7898 )
Changed: aaime @ Fri 30 Nov 2007 05:09:16 -0500
Comment: GEOS-1563, unclear problem in getcapabilities response
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/helpers/WMSCapsTransformer.java ( 7905 )
Changed: aaime @ Fri 30 Nov 2007 05:15:51 -0500
Comment: GEOS-1561, kml-ows5 build issues
Files changed:
  /branches/1.6.x/geoserver/community/kml-ows5/pom.xml ( 7907 )
Changed: aaime @ Tue 4 Dec 2007 10:28:15 -0500
Comment: GEOS-1541 Add listener to shapefile renderer so that rendering errors are reported at FINE logging level
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/DefaultRasterMapProducer.java ( 7925 )
Changed: aaime @ Tue 4 Dec 2007 10:31:16 -0500
Comment: GEOS-1571, Inconsistency between scale computed by GeoServer and OL map preview
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/openlayers/OpenLayersMapTemplate.ftl ( 7927 )
Changed: aaime @ Tue 4 Dec 2007 13:05:50 -0500
Comment: Improving TransactionListener and adding support methods to GeoServerTestSupport for custom spring files
Files changed:
  /branches/1.6.x/geoserver/main/src/test/java/org/geoserver/test/GeoServerTestSupport.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/DeleteElementHandler.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/InsertElementHandler.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/TransactionEvent.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/UpdateElementHandler.java ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTest.java (from /trunk/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTest.java:7930) ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTestContext.xml (from /trunk/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTestContext.xml:7930) ( 7931 )
  /branches/1.6.x/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTester.java (from /trunk/geoserver/wfs/src/test/java/org/geoserver/wfs/TransactionListenerTester.java:7930) ( 7931 )
  /branches/1.6.x/geoserver/wfsv/src/main/java/org/geoserver/wfsv/RollbackElementHandler.java ( 7931 )
Changed: aaime @ Tue 4 Dec 2007 14:21:10 -0500
Comment: GEOS-1568, Metatile cache expiry should be linked to config reload and transaction plugins
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/applicationContext.xml ( 7936 )
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/metatile/MetatileMapProducer.java ( 7936 )
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/metatile/QuickTileCache.java ( 7936 )
Changed: aaime @ Wed 5 Dec 2007 10:06:07 -0500
Comment: GEOS-1581, WCS Describe Coverage does not work properly with rotated coverages
Files changed:
  /branches/1.6.x/geoserver/main/src/main/java/org/vfny/geoserver/config/CoverageConfig.java ( 7937 )
  /branches/1.6.x/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java ( 7937 )
  /branches/1.6.x/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigWriter.java ( 7937 )
  /branches/1.6.x/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/DescribeResponse.java ( 7937 )
Changed: aaime @ Wed 5 Dec 2007 11:07:39 -0500
Comment: Make sure logging switch occurrs as early as possible
Files changed:
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/web.xml ( 7941 )
Changed: aaime @ Wed 5 Dec 2007 11:09:17 -0500
Comment: GEOS 1559 Geoserver (c) should have date and copyright holder's too
Files changed:
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/layouts/mainLayout.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/mapPreview.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/schemaErrors.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/WEB-INF/pages/srsList.jsp ( 7942 )
  /branches/1.6.x/geoserver/web/src/main/webapp/index.jsp ( 7942 )
Changed: aaime @ Wed 5 Dec 2007 13:09:38 -0500
Comment: GEOS-1585 Legend production fails if there is a raster symbolizer in the mix
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/DefaultRasterLegendProducer.java ( 7945 )
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/rasterLegend.png (from /trunk/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/rasterLegend.png:7944) ( 7945 )
Changed: arneke @ Wed 5 Dec 2007 15:06:27 -0500
Comment: GEOS-1577 the XMLwriter escapes certain characters, but they were not being unescaped by the reader
Files changed:
  /branches/1.6.x/geoserver/platform/src/main/java/org/geoserver/util/ReaderUtils.java ( 7946 )
Changed: aaime @ Wed 5 Dec 2007 15:17:13 -0500
Comment: Don't try to parse kvp is the map is empty
Files changed:
  /branches/1.6.x/geoserver/main/src/main/java/org/vfny/geoserver/servlets/JSPCompiler.java ( 7947 )
  /branches/1.6.x/geoserver/ows/src/main/java/org/geoserver/ows/Dispatcher.java ( 7947 )
Changed: aaime @ Thu 6 Dec 2007 04:58:08 -0500
Comment: Reformatted by removing the tabs. sigh..
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/svg/SVGBatikMapProducer.java ( 7949 )
Changed: aaime @ Thu 6 Dec 2007 06:24:02 -0500
Comment: Upgrading GeoApi since gt2 2.4.x did the same...
Files changed:
  /branches/1.6.x/geoserver/pom.xml ( 7950 )
Changed: aaime @ Thu 6 Dec 2007 06:37:25 -0500
Comment: GEOS-1589, Batik SVG output format generates no output at all
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/svg/SVGBatikMapProducer.java ( 7951 )
  /branches/1.6.x/geoserver/wms/src/test/java/org/vfny/geoserver/wms/responses/map/svg ( 7951 )
  /branches/1.6.x/geoserver/wms/src/test/java/org/vfny/geoserver/wms/responses/map/svg/SVGTest.java ( 7951 )
Changed: aaime @ Thu 6 Dec 2007 08:47:57 -0500
Comment: Whoops, forgot sysouts in the test
Files changed:
  /branches/1.6.x/geoserver/wms/src/test/java/org/vfny/geoserver/wms/responses/map/svg/SVGTest.java ( 7952 )
Changed: aaime @ Thu 6 Dec 2007 11:12:20 -0500
Comment: First fix for GEOS-1578, PROXY_BASE_URL configurationseems to only work part way
Files changed:
  /branches/1.6.x/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/WCSCapabilitiesResponse.java ( 7957 )
  /branches/1.6.x/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/WCSCapsTransformer.java ( 7957 )
  /branches/1.6.x/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/servlets/Capabilities.java ( 7957 )
Changed: arneke @ Thu 6 Dec 2007 11:25:43 -0500
Comment: Added null check
Files changed:
  /branches/1.6.x/geoserver/platform/src/main/java/org/geoserver/util/ReaderUtils.java ( 7958 )
Changed: dwinslow @ Fri 7 Dec 2007 14:51:21 -0500
Comment: GEOS-1591: (backport) Fixed text on login page to link to instructions on changing password manually.
Files changed:
  /branches/1.6.x/geoserver/web/src/main/java/ApplicationResources.properties ( 7964 )
Changed: dwinslow @ Mon 10 Dec 2007 15:24:18 -0500
Comment: GEOS-1566: Fixed duplicated output formats in GetCapabilities request.
Files changed:
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/CapabilitiesTransformer.java ( 7965 )
Changed: jdeolive @ Wed 12 Dec 2007 07:41:31 -0500
Comment: GEOS-1599, setting link to describe feature type property when describe feature type returns multiple types
Files changed:
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/FeatureTypeSchemaBuilder.java ( 7968 )
Changed: aaime @ Wed 12 Dec 2007 09:33:18 -0500
Comment: GEOS-1602 WFS 1.0 describe feature type output mixes single and double quotes
Files changed:
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/XmlSchemaEncoder.java ( 7971 )
Changed: jdeolive @ Wed 12 Dec 2007 11:15:49 -0500
Comment: GEOS-1558, injecting application schema namespaces for request parsing
Files changed:
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/WFSConfiguration.java ( 7974 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/WfsXmlReader.java ( 7974 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WFSConfiguration.java ( 7974 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WfsXmlReader.java ( 7974 )
Changed: aaime @ Wed 12 Dec 2007 11:36:25 -0500
Comment: Backported from trunk EMF oriented kvp parser base class
Files changed:
  /branches/1.6.x/geoserver/ows/src/main/java/org/geoserver/ows/kvp/EMFKvpRequestReader.java ( 7976 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/kvp/GetFeatureKvpRequestReader.java ( 7976 )
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/kvp/WFSKvpRequestReader.java ( 7976 )
Changed: aaime @ Wed 12 Dec 2007 12:30:50 -0500
Comment: Allow for subclasses to access fields
Files changed:
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WFSConfiguration.java ( 7978 )
Changed: aaime @ Wed 12 Dec 2007 12:40:54 -0500
Comment: Factored out result building so that subclasses can override
Files changed:
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/GetFeature.java ( 7980 )
Changed: aaime @ Wed 12 Dec 2007 12:45:18 -0500
Comment: Allow suclasses to change schema locations, prefixes and the like
Files changed:
  /branches/1.6.x/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/FeatureTypeSchemaBuilder.java ( 7982 )
Changed: arneke @ Wed 12 Dec 2007 14:45:53 -0500
Comment: GEOS-1603 WMS Reflector reprojection support, uses native bounds if possible.
Files changed:
  /branches/1.6.x/geoserver/wms/src/main/java/org/geoserver/wms/DefaultWebMapService.java ( 7984 )
Changed: jdeolive @ Wed 12 Dec 2007 14:50:44 -0500
Comment: GEOS-1597, dispatcher throwing exception when no request reader found
Files changed:
  /branches/1.6.x/geoserver/ows/src/main/java/org/geoserver/ows/Dispatcher.java ( 7986 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk4
Description: default maven2 buildDefinition
Test Summary:
Tests: 200
Failures: 0
Total time: 361.30798
