[Geoserver-devel] [continuum] BUILD SUCCESSFUL: GeoServer JDK5 - GeoServer - Build Def: default maven2 buildDefinition
Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=66&projectId=25
Build statistics:
  State: Ok
  Previous State: Building
  Started at: Fri 30 Nov 2007 06:56:11 -0500
  Finished at: Fri 30 Nov 2007 07:04:57 -0500
  Total time: 8m 46s
  Build Trigger: Schedule
  Build Number: 12
  Exit code: 0
  Building machine hostname: traffic.openplans.org
  Operating system : Linux(unknown)
  Java Home version : java version "1.5.0_12"
          Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
          Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
          Builder version :
          Maven version: 2.0.5
SCM Changes:
Changed: dwinslow @ Wed 28 Nov 2007 17:51:16 -0500
Comment: Restructured URLs for coverages so that coveragestore=>coverage is mapped similarly to datastore=>featuretype, as well as improving the amount of information that's exposed for coverages in general.
Files changed:
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageListResource.java ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageResource.java ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageStoreListResource.java ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageStoreResource.java ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/coverage.ftl ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/coveragestore.ftl ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/coveragestores.ftl ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/ResourceFinder.java ( 7892 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/WrappingController.java ( 7892 )
Changed: dwinslow @ Tue 27 Nov 2007 15:07:27 -0500
Comment: Added detail to the coverage information exposed
Files changed:
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageResource.java ( 7875 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/coverage.ftl ( 7875 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/head.ftl ( 7875 )
Changed: dwinslow @ Tue 27 Nov 2007 11:36:38 -0500
Comment: Made SLD's available again.
Files changed:
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/ResourceFinder.java ( 7872 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/StyleListResource.java ( 7872 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/StyleResource.java ( 7872 )
Changed: dwinslow @ Tue 27 Nov 2007 10:47:15 -0500
Comment: Conversion to MapResource mostly complete.
Files changed:
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageListResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DataFormat.java (from /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/restconfig/DataFormat.java:7864) ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DataStoreListResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DataStoreResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/FeatureTypeResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLFormat.java (from /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/restconfig/HTMLFormat.java:7864) ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/coverages.ftl ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/datastore.ftl ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/datastores.ftl ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/featuretype.ftl ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/index.ftl ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/styles.ftl ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/IndexResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/JSONFormat.java (from /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/restconfig/JSONFormat.java:7864) ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/LayerGroupResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/MapResource.java (from /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/restconfig/MapResource.java:7864) ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/ResourceFinder.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/StyleResource.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/WrappingController.java ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/XMLFormat.java (from /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/restconfig/XMLFormat.java:7864) ( 7871 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/XMLTemplate.java ( 7871 )
Changed: dwinslow @ Mon 19 Nov 2007 19:15:31 -0500
Comment: Updated JSON-lib to version 2.1
Files changed:
  /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/usermanagement/JSONFormat.java ( 7801 )
  /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/usermanagement/MapResource.java ( 7801 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageResource.java ( 7801 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DataStoreResource.java ( 7801 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/StyleResource.java ( 7801 )
  /trunk/geoserver/pom.xml ( 7801 )
Changed: dwinslow @ Thu 8 Nov 2007 17:50:39 -0500
Comment: Added Layer Group listing page.
Files changed:
  /trunk/geoserver/community/RESTConfig/pom.xml ( 7725 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/LayerGroupResource.java ( 7725 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/ResourceFinder.java ( 7725 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/WrappingController.java ( 7725 )
Changed: dwinslow @ Wed 7 Nov 2007 12:06:03 -0500
Comment: Provided initial implementation of Coverage and Style resources; fixed some problems with the Datastore/FeatureType hierarchy.
Files changed:
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/CoverageResource.java ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DataStoreResource.java ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplate.java ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/coverage.ftl ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/coverages.ftl ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/datastore.ftl ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/datastores.ftl ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/styles.ftl ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/ResourceFinder.java ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/StyleResource.java ( 7714 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/WrappingController.java ( 7714 )
Changed: arneke @ Mon 5 Nov 2007 11:18:44 -0500
Comment: RESTlet configuration, work in progress
Files changed:
  /trunk/geoserver/community/RESTConfig ( 7709 )
  /trunk/geoserver/community/RESTConfig/pom.xml ( 7709 )
  /trunk/geoserver/community/RESTConfig/src ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/applicationContext.xml ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DataStoreResource.java ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DummyRestlet.java ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/FeatureTypeResource.java ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplate.java ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/datastore.ftl ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/datastores.ftl ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/featuretype.ftl ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/head.ftl ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/HTMLTemplates/tail.ftl ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/ResourceFinder.java ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/WrappingController.java ( 7709 )
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/XMLTemplate.java ( 7709 )
Changed: dwinslow @ Wed 28 Nov 2007 17:51:49 -0500
Comment: Included XPath+JDOM support as a dependency for this module
Files changed:
  /trunk/geoserver/community/RESTConfig/pom.xml ( 7893 )
Changed: dwinslow @ Wed 28 Nov 2007 17:52:22 -0500
Comment: Keep numbers in Java as numbers in JSON
Files changed:
  /trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/JSONFormat.java ( 7894 )
Changed: dwinslow @ Wed 28 Nov 2007 17:53:17 -0500
Comment: Swapped tabs for spaces and reformatted code.
Files changed:
  /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/restconfig/MapResource.java ( 7895 )
  /trunk/geoserver/community/QueryUsers/src/main/java/org/geoserver/usermanagement/UserResource.java ( 7895 )
Changed: aaime @ Thu 29 Nov 2007 08:24:40 -0500
Comment: Fixing compile errors after Jody changed the name of a protected variable in a filter visitor superclass
Files changed:
  /trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/DefaultCRSFilterVisitor.java ( 7896 )
  /trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/ReprojectingFilterVisitor.java ( 7896 )
Changed: aaime @ Thu 29 Nov 2007 08:31:17 -0500
Comment: GEOS-1496 User 'format_options' to control modules of KML output
Files changed:
  /trunk/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5MapProducer.java ( 7897 )
  /trunk/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5Transformer.java ( 7897 )
  /trunk/geoserver/community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5VectorTransformer.java ( 7897 )
  /trunk/geoserver/community/kml-ows5/src/test/java/org ( 7897 )
  /trunk/geoserver/community/kml-ows5/src/test/java/org/geoserver ( 7897 )
  /trunk/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms ( 7897 )
  /trunk/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses ( 7897 )
  /trunk/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map ( 7897 )
Changed: aaime @ Thu 29 Nov 2007 10:40:58 -0500
Comment: Hide data dir location when tests are running
Files changed:
  /trunk/geoserver/main/src/main/java/TEST_LOGGING.properties ( 7899 )
Changed: aaime @ Thu 29 Nov 2007 10:52:42 -0500
Comment: Factored out validating dom read into the superclass... may be interesting to have in the GeoserverTestSupport itself in fact...
Files changed:
  /trunk/geoserver/community/wcs111/src/test/java/org/geoserver/wcs/GetCapabilitiesTest.java ( 7903 )
  /trunk/geoserver/community/wcs111/src/test/java/org/geoserver/wcs/test/WCSTestSupport.java ( 7903 )
Changed: aaime @ Fri 30 Nov 2007 04:54:11 -0500
Comment: GEOS-1563, unclear problem in getcapabilities response
Files changed:
  /trunk/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/helpers/WMSCapsTransformer.java ( 7904 )
Changed: aaime @ Fri 30 Nov 2007 05:13:15 -0500
Comment: GEOS-1561, kml-ows5 build issues
Files changed:
  /trunk/geoserver/community/kml-ows5/pom.xml ( 7906 )
Changed: aaime @ Fri 30 Nov 2007 06:13:38 -0500
Comment: Fix for GEOS-1368, kml processes/returns features that dont match any rules in the sld
Files changed:
  /trunk/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLTransformer.java ( 7908 )
  /trunk/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLVectorTransformer.java ( 7908 )
  /trunk/geoserver/wms/src/test/java/org/geoserver/wms/WMSTestSupport.java ( 7908 )
  /trunk/geoserver/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/KMLTransformerTest.java ( 7908 )
  /trunk/geoserver/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/singlefeature.sld ( 7908 )
Changed: aaime @ Fri 30 Nov 2007 06:16:58 -0500
Comment: Strange, this test passes in eclipse but not in maven...
Files changed:
  /trunk/geoserver/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/KMLTransformerTest.java ( 7909 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk5
Description: default maven2 buildDefinition
Test Summary:
Tests: 196
Failures: 0
Total time: 322.391
