Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=293&projectId=25
Build statistics:
State: Ok
Previous State: Failed
Started at: Thu 6 Dec 2007 11:05:17 -0500
Finished at: Thu 6 Dec 2007 11:13:48 -0500
Total time: 8m 31s
Build Trigger: Schedule
Build Number: 31
Exit code: 0
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.5.0_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Thu 6 Dec 2007 11:04:17 -0500
Comment: Fixing trunk build by upgrading geoapi to the version used by gt2
Files changed:
/trunk/geoserver/pom.xml ( 7956 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk5
Description: default maven2 buildDefinition
Test Summary:
Tests: 201
Failures: 0
Total time: 283.264
