Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=386&projectId=25
Build statistics:
State: Ok
Previous State: Failed
Started at: Wed 12 Dec 2007 12:57:05 -0500
Finished at: Wed 12 Dec 2007 13:07:05 -0500
Total time: 10m 0s
Build Trigger: Schedule
Build Number: 37
Exit code: 0
Building machine hostname: traffic.openplans.org
Operating system : Linux(unknown)
Java Home version : java version "1.5.0_12"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
Builder version :
Maven version: 2.0.5
SCM Changes:
Changed: aaime @ Wed 12 Dec 2007 12:39:28 -0500
Comment: Allow for subclasses to access fields
Files changed:
/trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WFSConfiguration.java ( 7979 )
Changed: aaime @ Wed 12 Dec 2007 12:44:39 -0500
Comment: Factored out result building so that subclasses can override
Files changed:
/trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/GetFeature.java ( 7981 )
Changed: aaime @ Wed 12 Dec 2007 12:47:00 -0500
Comment: Allow suclasses to change schema locations, prefixes and the like
Files changed:
/trunk/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/FeatureTypeSchemaBuilder.java ( 7983 )
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk5
Description: default maven2 buildDefinition
Test Summary:
Tests: 201
Failures: 0
Total time: 330.782
