lately I've bee working on a new LabelCache implementation
for a customer of OpenGeo. The LabelCache in question is
a heavy refactoring of the existing DefaultLabelCache,
but changes are so deep that it's mid-way between an
improvement and a total rewrite.
The new features I'm implementing are:
- label displacement on linear features: in case of conflict
with an existing label, the labeller tries to move the
label point up to x pixels away (along the line) to find
a free location
- label repetition on long linear features: the first label
point in the middle of the line, the others x pixels away
from each other (pixels measured along the line)
- multiple labels per line group: grouping usually results in
merging a group of lines into a smaller set of longer lines.
Usually only the longest gets labelled, with this option all
get labelled
- in group min distance for linear features: make sure there
is a minimum cartesian distance between every two labels in
a group. This helps when a group is made up of multiple
non subsequent lines, and when there is a single line that
makes a very close U turn (eventually going back on itself,
like bus routes often do).
- label along a line (aka curved labels)
- multi line labels, with split on newlines and when
a certain maximum line length is reached (splitting on word
boundaries)
So far I've implemented the displacement and the line group
related features, and started working on curved labels (whether
I'll work on multiline ones is still on the hook).
Now, the question is, how do I contribute the change back
into GeoServer/GeoTools? The change is tentatively scheduled
to go into GeoServer 1.7.2 (as the new default labeller),
yet it's quite a change.
GeoServer wise, I'd propose to make it the default labeller,
but allow an option (System variable) to disable it and go back
to the old labeller. I could even contribute it to 1.7.1
and play it the other way, that is, have the new labeller disabled
by default, and enabled when a certain option is set, to gather
early feedback.
GeoTools wise, I guess I can contribute it on 2.5.x and trunk
under a different name, make it the default labeller on trunk,
and just let it as an option on 2.5.x (the label cache used by
the renderer is already customizable, can be set as a rendering
hint).
So... opinions?
Andrea Aime
OpenGeo - http://opengeo.org
