Ciao Andrea,
I was waiting for someone else feedback, but I would go for leaving
the geofence code as a separate project under the GeoServer
organziation for the moment while having the probe (the custom
ResourceAccessManager implementation ) as a community module of
GeoServer.
I guess this is a +1 anyway.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Oct 1, 2014 at 3:16 PM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
any core developer interested in this one?
Need a +1, or even a -1, if you have concerns discussing them would allow
us to see if they can be addressed somehow.
On Sat, Sep 27, 2014 at 8:17 AM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
since the last thread started revolving around the name mistake instead of
the
actual content of the mail, let me start again and let's gather some
feedback
about the actual module., shall we?
in the last years GeoSolutions has been working on a "advanced security
subsystem"
known as GeoFence.
The code consists of a ResourceAccessManager implementation that talks to
a
GeoFence server, which evaluates access requests and sends back
"entiltements",
that is, what the user can do in terms of request access and so on.
The GeoFence webapp also contains a GWT front-end allowing an easy setup
of access rules, but it is also possible to extract and edit the rules via
a REST API.
We could like to donate the ResourceAccessManager implementation as a
community module, and the service/UI/rest webapp as a separate project to
be
stored under the geoserver organization (pretty much like the cite engine
tools).
Or, we could also move all the code in GeoServer itself, and have these
module
generate war files as needed.
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
