When GeoServer is initializing the Control Flow extension, it will log an
error message if the "ip.blacklist" and/or "ip.whitelist" properties are
used in controlflow.properties. For example,
ERROR [org.geoserver.flow.config] Rules should be assigned just a queue
size, instead ip.blacklist is associated to 127.0.0.1
The error message(s) are harmless since those properties are used by a
different class than the one logging the errors and there does not appear to
be any loss of functionality. The error messages were cause by this commit:
where it changed from:
if(!"ip.blacklist".equals(key) && !"ip.whitelist".equals(key)){
...do stuff
}else{
continue;
to:
if("ip.blacklist".equals(key) && "ip.whitelist".equals(key)) {
continue;
} else {
...do stuff
but it should be using or instead of and:
if("ip.blacklist".equals(key) || "ip.whitelist".equals(key)) {
continue;
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/Control-Flow-blacklist-whitelist-Error-Message-tp5323421.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
