[Geoserver-devel] Control flow: rate limiting and more dynamic configuration
I’m looking into some possible improvements for control-flow and would
like to discuss them with the community.
First, we’d like to have the ability to create control flow rules on a per
request basis, in particular, to keep track of the user that’s making them
(this is unfornatuely going to be based on a pre-existing user management
system, so I won’t be able to merge into GeoServer also the user specific
portion, but at least this will make it doable later down the road).
Of course in order to work properly the flow controllers need to be long
lived, not created on the fly by the request, but we want to make
the ControlFlowConfigurator be responsible for it.
So, the ControlFlowConfigurator would be changed to switch from this:
public interface ControlFlowConfigurator {
  • Builds the set of flow controllers to be used in the {@link ControlFlowCallback}
    Collection buildFlowControllers() throws Exception;
  • Maximum time the request can be held in queue before giving up to it.
  • @return The maximum time in milliseconds. Use 0 or a negative number for no timeout
    long getTimeout();
  • Returns true if the set of flow controllers changed since last invocation of
  • {@link #buildFlowControllers()}
  • @return
    boolean isStale();
to this:
    List getFlowControllers() throws Exception;
    long getTimeout();
Significant changes:
  • The configurator returns an already sorted list of controllers, it’s up to the configurator to
    put them in the desired order
  • Since the getFlowController() method will be called for each request, the configurator
    will be responsible of managing the lifetime of the controllers, and the ControlFlowCallback
    will keep the list of controllers in a callback
The second change we’d like to propose is rate limiting, that is, allow controlling how many
requests per unit of time we allow, and eventually delay the excess.
The rules would look more or less like this:
user.ows[.service[.request[.outputformat]]]=10/s;1s
ip.ows[.service[.request[.outputformat]]]=10/s;1s
That is, we make it user or ip based, and we express a max amount of requests in a unit
of time (s, m, h, d), and then an eventual delay with a unit of measure.
Last, but not least, in case a request ends up waiting too much, we should be returning
a HTTP 429 instead of the current 403, and allow have the flow controllers add one
or more HTTP headers to the response in case the request are getting blocked,
as a debugging facilitation (and to make it more evident that a request flow control
is in place).
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
assuming there is no feedback on this, I’ll move one with the changes.
Thinking about it, and in order to avoid interface breakage in case someone ControlFlowConfigurator,
I’ll create a new interface for the flow controller provider, with a default implementation that
just finds today’s ControlFlowConfigurator and exposes its functionality via:
public interface FlowControllerProvider {
  • Returns the set of flow controllers to be used in the {@link ControlFlowCallback}
    long getTimeout();
On Mon, Oct 20, 2014 at 3:11 PM, Andrea Aime <andrea.aime@anonymised.com8…> wrote:
    long getTimeout();
  • @return
    boolean isStale();
to this:
    long getTimeout();
is in place).
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
The changes sound pretty sensible. No objections here. One question is if there is going to be any backwards compatibility issues configuration wise?
On Tue, Oct 21, 2014 at 6:11 AM, Andrea Aime <andrea.aime@anonymised.com8…> wrote:
    long getTimeout();
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
On Mon, Oct 20, 2014 at 3:11 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
    long getTimeout();
  • @return
    boolean isStale();
to this:
    long getTimeout();
is in place).
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Oct 21, 2014 at 3:49 PM, Justin Deoliveira <
Hum... good question.
Nope, I don't think so, the keys in the property file are not overlapping
with older ones
Ing. Andrea Aime
@geowolf
Technical Lead
