On Thu, Apr 13, 2017 at 3:17 PM, Justin Deoliveira <jdeolive@anonymised.com>
wrote:
Hey Andrea,
Thanks for the input. Adding multiple keys at the top level would
certainly be an option, I just figured that since there are already quite a
few kml format options keys that having it encapsulated into a single one
would be a little nicer, and more aesthetically pleasing.
To be clear I wasn’t proposing any change to format options syntax or
parser, just to see if someone had done this sort of thing before. My
thinking was that as long I chose delimiters that aren’t currently used (ie
not one of “&”, “=“, “:”, or “;”) then it should be pretty uninvasive and
not introduce any compatibility issues.
I'm not so sure, the format options parser is used for more than just
format options:
wfs/src/main/java/applicationContext.xml: <bean
id="wfsFormatOptionsKvpParser"
class="org.geoserver.ows.kvp.FormatOptionsKvpParser"/>
wms/src/main/java/applicationContext.xml: <bean
id="wmsFormatOptionsKvpParser"
id="wmsEnviromentKvpParser"
class="org.geoserver.ows.kvp.FormatOptionsKvpParser">
id="wmsLegendOptionsKvpParser"
While I agree you can guess by looking at the existing format options what
chars are not used (at least in the official GeoServer code base), I would
not try to make the
same guess about env vars (anything goes in there, imho). If you really
want to go there, I'd add a parameter to limit the nested options
properties to just the
real format options parsers (the wms and wfs ones).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
