[Geoserver-devel] Convert custom projection from meters to degrees
I am trying to convert projection EPSG:3413 from meters to degrees.
Below is the WKT for the projection:
PROJCS["WGS 84 / NSIDC Sea Ice Polar Stereographic North",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563,
AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Geodetic longitude", EAST],
    AXIS["Geodetic latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Polar Stereographic (variant B)", AUTHORITY["EPSG","9829"]],
  PARAMETER["central_meridian", -45.0],
  PARAMETER["Standard_Parallel_1", 70.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", "South along 45 deg East"],
  AXIS["Northing", "South along 135 deg East"],
  AUTHORITY["EPSG","3413"]]
I followed these steps
(https://www.lizardtech.com/support/knowledge-base-article/how-do-i-create-a-custom-wkt-to-change-meters-to-feet/)
to convert the above projection into degrees and this is what I came up
with:
  GEOGCS["WGS 84",
  AXIS["Northing", "South along 135 deg East"]]
When I attempt to display a layer in this projection, no data (an empty
image) is returned by GeoServer and GeoServer does not throw any errors.
I am using the area of validity as my bbox: 90°00'00.0"N, 180°00'00.0"W -
60°00'00.0"N, 180°00'00.0"E
(which I translated to bbox: -180,60,180,90).
Can anyone tell me if my translation of the projection or bbox is incorrect?
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Convert-custom-projection-from-meters-to-degrees-tp5133614.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Does anyone know of any consultants who could help with this problem?
We need it solved asap. Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Convert-custom-projection-from-meters-to-degrees-tp5133614p5135465.html
