[Geoserver-devel] Convert raster GetFeatureInfo band names into NCNames?
Raster band names containing spaces cause malformed XML GetFeatureInfo responses:
https://osgeo-org.atlassian.net/browse/GEOS-7717
https://github.com/geoserver/geoserver/pull/1799
The above pull request converts band names to NCNames by replacing illegal characters like spaces and leading digits with underscore ("_").
This proposed change will also affect plain text, HTML, and JSON GetFeatureInfo responses. I like this because it is consistent, but it is a behavioural change and some users might not want it.
Does anyone object to this change? If so, I could look into making this change elsewhere, for example, in the output format. I think this will be uglier and make the formats inconsistent.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
On Mon, Sep 5, 2016 at 11:14 PM, Ben Caradoc-Davies <ben@anonymised.com>
responses:
As a user, if I am allowed to configure a band name in the layer page
with spaces and other weird chars, I would really love my decision
to be respected to the extent where it's possible (GML does not allow
it, but it's the only GetFeaturInfo case).
That said, it's a preference, I'm not hellbent on it, I just find annoying
to
see GML limitations creeping out in other parts of the code.
In case you want to perform on the fly renaming the gt-transform module
has some support to perform the renames without having to write custom
code,
although you'll have to first wrap the collection in a feature source to
use it
(DataUtiltiies has a method to do that).
Again just an opinion, but coming from a coverage background GML is the
ugly one here :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
as a follow-up, if no one has anything more to pitch in, I’d say Ben go ahead with your change,
if nobody else cares one way or the other it’s probably a good indication that there is no need
to rework your current pull request
On Wed, Sep 7, 2016 at 12:07 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Sep 5, 2016 at 11:14 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
responses:
illegal characters like spaces and leading digits with underscore (“_”).
to be respected to the extent where it’s possible (GML does not allow
it, but it’s the only GetFeaturInfo case).
That said, it’s a preference, I’m not hellbent on it, I just find annoying to
has some support to perform the renames without having to write custom code,
although you’ll have to first wrap the collection in a feature source to use it
Again just an opinion, but coming from a coverage background GML is the ugly one here :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, Andrea, merged on master.
Although this pull request restricts the output property names for non-GML info_formats, by doing so it makes output for all info_formats consistent.
The next question is: should this be backported to 2.9.x? It is a behavioural change, but also a bug fix.
Kind regards,
Ben.
On 08/09/16 20:30, Andrea Aime wrote:
as a follow-up, if no one has anything more to pitch in, I'd say Ben go
if nobody else cares one way or the other it's probably a good indication
responses:
to
code,
use it
Ing. Andrea Aime
@geowolf
Technical Lead
Director
New Zealand
If there is no objection, I would like to backport this to 2.9.x for inclusion in 2.9.2.
Kind regards,
Ben.
consistent.
Kind regards,
Ben.
responses:
to
code,
use it
Ing. Andrea Aime
@geowolf
Technical Lead
Director
New Zealand
