The problem occurs, when configuring the FeatureType with a registered
WPSDataStore through the web admin. It actually appears, when I trigger
the typeNew.do Action (DataFeatureTypesNewAction). There is no
possibiltiy to set the EPSG, or can I configure that at a different
type?
Theodor
-----Original Message-----
Sent: Friday, September 01, 2006 11:37 PM
To: Theodor Foerster
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] CoordinateSystem null in DefaultGeometry
- geoserver 1.3.0 src
Is this when you're using the web admin? Did you fill out an epsg code
in the web admin?
I've never looked in to this code super extensively, but basically some
datastores can provide their epsg information and automatically fill out
that field, and others can't. If yours can't then the user just fills
out what it is.
I'm not sure if geotools gml parsing figures out the epsg, and actually
I know we don't support gml 3.2.0, so it probably can't figure it out.
I think you may be able to get away with just having your datastore
return some hard coded CRS, and then let users fill out the proper epsg
code.
Chris
Theodor Foerster wrote:
I just get a nullpointerException at
DataFeatureTypesNewAction.execute():109. The crs seems to be empty.
However I do not have an idea why. I just pass in a 3.2.0 GML schema
(provided by my WPSDataStore). Should actually work (IMHO), or what is
such Action waiting for? Is there a working gml schema?
Thanks for your help.
Theodor
ITC, Enschede
Department of Geo Information Processing PO. Box 6 7500 AA Enschede
the Netherlands
--- Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=1216
42 _______________________________________________
Geoserver-devel mailing list
!DSPAM:1003,44f85b50254861460912952!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
