[Geoserver-devel] Corrupt KML in 1.6 Beta
I'm using 1.6 Beta and successfully displaying ArcSDE vector data and
shapefile data within OpenLayers and PDF (via GeoServer's Demo/Map Preview
area. When I use the KML option, the resulting file appears to be corrupt,
it is missing some data and I'm unable to view it. Here's an example of the
file:
<html>
<head><title>GeoServer - Exception</title>
  <meta content="text/css" http-equiv="content-style-type">
  <style type="text/css">
    <!-- @import url("/geoserver/style.css"); -->
  </style>
  <link type="image/gif" href="gs.gif" rel="icon"><!-- mozilla -->
  <link href="gs.ico" rel="SHORTCUT ICON"><!-- ie -->
</head>
<body>
<h1>GeoServer - Exception</h1>
The following exception was thrown:
<br>
<code>java.lang.NullPointerException</code>
</body>
</html>
Any thoughts of what I should check?
Thanks, Bob
View this message in context: http://www.nabble.com/Corrupt-KML-in-1.6-Beta-tf4609518.html#a13163223
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Can you turn on 'verbose exceptions' in Config -> Server?
And then try to do: http://localhost:8080/geoserver/wms/kml_reflect?layers=&lt;your layer name>
Chris
Bob Nutsch wrote:
file:
<html>
  </style>
  <link type="image/gif" href="gs.gif" rel="icon"><!-- mozilla --> <link href="gs.ico" rel="SHORTCUT ICON"><!-- ie -->
</head>
<body>
<br>
<code>java.lang.NullPointerException</code> </body>
</html>
Thanks, Bob
this looks very much like http://jira.codehaus.org/browse/GEOS-1360 which
seems to have been fixed for beta4
View this message in context: http://www.nabble.com/Corrupt-KML-in-1.6-Beta-tf4609518.html#a13173591
HI Chris,
I set both Verbose and VerboseExceptions to be one, and the URL that I issue
is then:
http://localhost:8090/geoserver/wms/kml_reflect?layers=NDHUB:NDHUB.COUNTIES_POLY
When I go to Demo - Map Preview, the item that I'm trying to use with KML
looks like the attached .gif. I'm showing this should I have the syntax
incorrect. I've tried with with and without the "NDHUB:" and get the same
contents of the KML as shown in my original post.
http://www.nabble.com/file/p13174220/demoview.gif
Thanks, Bob
And then try to do:
Chris
Bob Nutsch wrote:
Preview
corrupt,
the
file:
<html>
  </style>
</head>
<body>
<br>
</body>
</html>
Thanks, Bob
begin:vcard
fn:Chris Holmes
n:Holmes;Chris
org:The Open Planning Project
adr:;;349 W. 12th Street, #3;New York;NY;10014;USA
email;internet:cholmes@anonymised.com
title:Managing Director, Strategic Development
x-mozilla-html:FALSE
url:http://topp.openplans.org
version:2.1
end:vcard
Geoserver-devel mailing list
View this message in context: http://www.nabble.com/Corrupt-KML-in-1.6-Beta-tf4609518.html#a13174220
Bob Nutsch ha scritto:
HI Chris,
is then:
Bob,
we need the stack trace you can find in the GeoServer logs. If you're
running GeoServer manually you should see it in the console where
GeoServer was started, otherwise if you can enable logging in
configuration/server you'll find a log file in the geoserver data dir.
Bob,
Which beta are you using exactly? In beta3 there was a serious problem
with kml generation in that it did not work at all.
Unfortunately we dont have nightly builds at the moment so I cant point
you at something to try out. But my impression is that you see this
fixed in the next release.
However the stack trace from your console would still be nice to just
confirm that this is the problem.
-Justin
HI Chris,
is then:
Bob,
!DSPAM:4007,470f727c107231637810514!
Justin Deoliveira
Hi Justin,
I'm using the geoserver-1.6-beta3.exe, dated September 18, with the
downloaded from
http://sourceforge.net/project/showfiles.php?group_id=25086
Here's that trace (captured from the console after the server is
running):
19641 [main] INFO org.mortbay.log - Started SelectChannelConnector @
0.0.0.0:8090
30563 [btpool0-6] INFO org.vfny.geoserver.wms.servlets - KML NetworkLink
sharing 1 layer(s) created.
30579 [btpool0-6] ERROR org.mortbay.log - /geoserver/wms/kml_reflect:
        at java.net.URI$Parser.parse(URI.java:3010)
        at java.net.URI.<init>(URI.java:578)
        at
org.geoserver.ows.util.RequestUtils.proxifiedBaseURL(RequestUtils.java:6
3)
        at
org.vfny.geoserver.wms.servlets.KMLReflector.doGet(KMLReflector.java:252
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:1054)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(Filt
erChainProxy.java
:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterS
ecurityIntercepto
r.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Filte
rSecurityIntercep
tor.java:72)
        at
erChainProxy.java
:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTransl
ationFilter.java:
110)
        at
erChainProxy.java
:274)
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter
(AnonymousProcess
ingFilter.java:125)
        at
erChainProxy.java
:274)
        at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProce
ssingFilter.java:
178)
        at
erChainProxy.java
:274)
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(H
ttpSessionContext
IntegrationFilter.java:229)
        at
erChainProxy.java
:274)
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:1
48)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java
:98)
        at
dler.java:1045)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharac
terEncodingFilter
.java:108)
        at
dler.java:1045)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
        at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandler
Collection.java:1
49)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.jav
a:123)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
        at org.mortbay.jetty.Server.handle(Server.java:303)
        at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConne
ction.java:721)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:509)
        at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
        at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:
320)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.ja
va:475)
        at
3)
        at
        at
        at
dler.java:1054)
        at
erChainProxy.java
:264)
        at
ecurityIntercepto
r.java:107)
        at
rSecurityIntercep
tor.java:72)
        at
erChainProxy.java
:274)
        at
ationFilter.java:
110)
        at
erChainProxy.java
:274)
        at
(AnonymousProcess
ingFilter.java:125)
        at
erChainProxy.java
:274)
        at
ssingFilter.java:
178)
        at
erChainProxy.java
:274)
        at
ttpSessionContext
        at
erChainProxy.java
:274)
        at
48)
        at
:98)
        at
dler.java:1045)
        at
terEncodingFilter
.java:108)
        at
dler.java:1045)
        at
        at
        at
        at
        at
Collection.java:1
49)
        at
a:123)
        at
        at
        at
ction.java:721)
        at
        at
        at
320)
        at
va:475)
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Friday, October 12, 2007 10:53 AM
To: Andrea Aime
Cc: Nutsch, Bob D.; geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Corrupt KML in 1.6 Beta
Bob,
serious problem with kml generation in that it did not work at all.
cant point you at something to try out. But my impression is
that you see this fixed in the next release.
to just confirm that this is the problem.
-Justin
>> HI Chris,
the URL that
>> I issue is then:
> Bob,
If you're
geoserver data dir.
> Cheers
> Andrea
> --- This SF.net email is sponsored by: Splunk Inc.
and a browser.
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Justin Deoliveira
I'm using geoserver-1.6-beta3.exe in my tests.
The trace looks like this:
0.0.0.0:8090
        at
org.geoserver.ows.util.RequestUtils.proxifiedBaseURL(RequestUtils.java:63)
        at
org.vfny.geoserver.wms.servlets.KMLReflector.doGet(KMLReflector.java:252)
        at
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java
:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityIntercepto
r.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityIntercep
tor.java:72)
        at
:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:
110)
        at
:274)
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcess
ingFilter.java:125)
        at
:274)
        at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:
178)
        at
:274)
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContext
        at
:274)
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter
.java:108)
        at
        at
        at
        at
        at
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:1
49)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
        at
        at
        at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:721)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
        at
        at
        at
        at
        at
:264)
        at
r.java:107)
        at
tor.java:72)
        at
:274)
        at
110)
        at
:274)
        at
ingFilter.java:125)
        at
:274)
        at
178)
        at
:274)
        at
        at
:274)
        at
        at
        at
        at
.java:108)
        at
        at
        at
        at
        at
        at
49)
        at
        at
        at
        at
        at
        at
HI Chris,
issue
is then:
Bob,
View this message in context: http://www.nabble.com/Corrupt-KML-in-1.6-Beta-tf4609518.html#a13177771
Yup, this is the exact issue. I am working on getting out nightly builds
going again. that will hepefully happen today. I will send an email
letting you know if you can try out a new build.
-Justin
Nutsch, Bob D. wrote:
Hi Justin,
downloaded from
running):
0.0.0.0:8090
        at
3)
        at
        at
        at
dler.java:1054)
        at
erChainProxy.java
:264)
        at
ecurityIntercepto
r.java:107)
        at
rSecurityIntercep
tor.java:72)
        at
erChainProxy.java
:274)
        at
ationFilter.java:
110)
        at
erChainProxy.java
:274)
        at
(AnonymousProcess
ingFilter.java:125)
        at
erChainProxy.java
:274)
        at
ssingFilter.java:
178)
        at
erChainProxy.java
:274)
        at
ttpSessionContext
        at
erChainProxy.java
:274)
        at
48)
        at
:98)
        at
dler.java:1045)
        at
terEncodingFilter
.java:108)
        at
dler.java:1045)
        at
        at
        at
        at
        at
Collection.java:1
49)
        at
a:123)
        at
        at
        at
ction.java:721)
        at
        at
        at
320)
        at
va:475)
        at
3)
        at
        at
        at
dler.java:1054)
        at
erChainProxy.java
:264)
        at
ecurityIntercepto
r.java:107)
        at
rSecurityIntercep
tor.java:72)
        at
erChainProxy.java
:274)
        at
ationFilter.java:
110)
        at
erChainProxy.java
:274)
        at
(AnonymousProcess
ingFilter.java:125)
        at
erChainProxy.java
:274)
        at
ssingFilter.java:
178)
        at
erChainProxy.java
:274)
        at
ttpSessionContext
        at
erChainProxy.java
:274)
        at
48)
        at
:98)
        at
dler.java:1045)
        at
terEncodingFilter
.java:108)
        at
dler.java:1045)
        at
        at
        at
        at
        at
Collection.java:1
49)
        at
a:123)
        at
        at
        at
ction.java:721)
        at
        at
        at
320)
        at
va:475)
To: Andrea Aime
Bob,
-Justin
HI Chris,
the URL that
I issue is then:
Bob,
If you're
geoserver data dir.
and a browser.
Justin Deoliveira
!DSPAM:4007,470fc64a299253668746562!
Justin Deoliveira
Great! And thanks!
Bob
Sent: Friday, October 12, 2007 2:30 PM
To: Nutsch, Bob D.
Cc: Andrea Aime; geoserver-devel@lists.sourceforge.net
nightly builds going again. that will hepefully happen today.
I will send an email letting you know if you can try out a new build.
-Justin
> Hi Justin,
> downloaded from
> running):
> 0.0.0.0:8090
> NetworkLink sharing 1 layer(s) created.
> at
> :6
> 3)
> at
> 52
> at
> at
> at
> at
> an
> dler.java:1054)
> at
> lt
> erChainProxy.java
> :264)
> at
> rS
> ecurityIntercepto
> r.java:107)
> at
> te
> rSecurityIntercep
> tor.java:72)
> at
> lt
> erChainProxy.java
> :274)
> at
> sl
> ationFilter.java:
> 110)
> at
> lt
> erChainProxy.java
> :274)
> at
> er
> (AnonymousProcess
> ingFilter.java:125)
> at
> lt
> erChainProxy.java
> :274)
> at
> ce
> ssingFilter.java:
> 178)
> at
> lt
> erChainProxy.java
> :274)
> at
> (H
> ttpSessionContext
> at
> lt
> erChainProxy.java
> :274)
> at
> :1
> 48)
> at
> va
> :98)
> at
> an
> dler.java:1045)
> at
> ac
> terEncodingFilter
> .java:108)
> at
> an
> dler.java:1045)
> at
.java:358)
> at
.java:231)
> at
.java:629)
> at
> at
> er
> Collection.java:1
> 49)
> at
> av
> a:123)
> at
.java:141)
> at
java:452)
> at
> ne
> ction.java:721)
> at
> at
> at
> at
oint.java:
> 320)
> at
> ja
> va:475)
> at
> :6
> 3)
> at
> 52
> at
> at
> at
> at
> an
> dler.java:1054)
> at
> lt
> erChainProxy.java
> :264)
> at
> rS
> ecurityIntercepto
> r.java:107)
> at
> te
> rSecurityIntercep
> tor.java:72)
> at
> lt
> erChainProxy.java
> :274)
> at
> sl
> ationFilter.java:
> 110)
> at
> lt
> erChainProxy.java
> :274)
> at
> er
> (AnonymousProcess
> ingFilter.java:125)
> at
> lt
> erChainProxy.java
> :274)
> at
> ce
> ssingFilter.java:
> 178)
> at
> lt
> erChainProxy.java
> :274)
> at
> (H
> ttpSessionContext
> at
> lt
> erChainProxy.java
> :274)
> at
> :1
> 48)
> at
> va
> :98)
> at
> an
> dler.java:1045)
> at
> ac
> terEncodingFilter
> .java:108)
> at
> an
> dler.java:1045)
> at
.java:358)
> at
.java:231)
> at
.java:629)
> at
> at
> er
> Collection.java:1
> 49)
> at
> av
> a:123)
> at
.java:141)
> at
java:452)
> at
> ne
> ction.java:721)
> at
> at
> at
> at
oint.java:
> 320)
> at
> ja
> va:475)
>> To: Andrea Aime
>> Bob,
that you see
nice to just
>> -Justin
>>>> HI Chris,
>> the URL that
>>>> I issue is then:
>>> Bob,
>> If you're
>> geoserver data dir.
>>> Cheers
>>> Andrea
>> and a browser.
>>> _______________________________________________
>> Justin Deoliveira
and a browser.
Justin Deoliveira
