that may well be a regression, this use case you’re after is pretty uncommon and I’ve seen
it used only by Oracle users.
Since you can develop I’d make a pull request, with a test, by changing the following two extra files:
From what I can tell use of the MetadataTablePrimaryKeyFinder does not matter. The code is still going to hit the test in JDBCFeatureSource.buildFeatureType() that decides to make the feature read-only if there’s a vtable. Fwiw the code was finding my primary key anyway by using Oracle data dictionary info. I had read-only then and now when using a pk metadata table I’m still read-only.
I changed the code and did a successful WFS-T Insert.
My edit changes this:
if(pkey == null || pkey instanceof NullPrimaryKey || virtualTable != null) {
To this:
if(pkey == null || pkey instanceof NullPrimaryKey) {
Sent: Tuesday, May 9, 2017 12:19 PM
To: ‘Andrea Aime’ <andrea.aime@…1268…>
Cc: geoserver-devel@lists.sourceforge.net
Subject: RE: [Geoserver-devel] Could a “simple” geoserver view become updatable?
Yes it gets hit. But it seems like the only thing anything outside that class would call is getPrimaryKey. And that never gets hit.
From: andrea.aime@…403… [mailto:andrea.aime@…403…] On Behalf Of Andrea Aime
Sent: Tuesday, May 9, 2017 12:17 PM
To: Walter Stovall <walter.stovall@…4309…>
Subject: Re: [Geoserver-devel] Could a “simple” geoserver view become updatable?
Is the MetadataTablePrimaryKeyFinder hit and used?
I’d put breakpoints in it and have a look.
On Tue, May 9, 2017 at 6:13 PM, Walter Stovall <walter.stovall@…4309…> wrote:
I’m having trouble making updatable views work. I have the pk metadata table setup and configured.
Debugging the WFS-T I’m hitting this code in JDBCFeatureSource.buildFeatureType()…
// setup the read only marker if no pk or null pk or it’s a view
boolean readOnly = false;
readOnly = true;
So pkey is setup but the virtualTable != null test then forces it read-only anyway – seems counter to what http://docs.geoserver.org/stable/en/user/data/database/primarykey.html#using-the-metadata-table-with-views says about being able to update views?
Can you suggest anything here?
Walter Stovall
Byers Engineering Company
Sent: Tuesday, May 9, 2017 8:23 AM
On Tue, May 9, 2017 at 1:30 PM, Walter Stovall <walter.stovall@…4309…> wrote:
My application builds geoserver layers that are based on a “view” as defined by a Oracle SELECT statement pasted into the geoserver layer editor. By using a view my layer becomes read-only, but I want to update via WFS-T transactions.
The configure it accordingly
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
