We are using updateable Oracle views in a production system with some pretty old Geoserver so we know it works. It would be nice to know the dates of last changes in the related source files because that may prevent us from updating.
-Jukka Rahkonen-
Walter Stovall wrote
Re: [Geoserver-devel] Could a “simple” geoserver view become updatable?
Why would you think this problem is specific to Oracle? The code I’m changing is in JDBCFeatureSource.buildFeatureType() at its virtualTable != null test, which I would think applies to jdbc data sources in general, not just Oracle. Am I missing something there?
From: andrea.aime@…403… [mailto:andrea.aime@…403…] On Behalf Of Andrea Aime
Sent: Tuesday, May 9, 2017 12:50 PM
To: Walter Stovall <walter.stovall@…4309…>
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Could a “simple” geoserver view become updatable?
Hi Water,
that may well be a regression, this use case you’re after is pretty uncommon and I’ve seen
it used only by Oracle users.
Since you can develop I’d make a pull request, with a test, by changing the following two extra files:
On Tue, May 9, 2017 at 6:45 PM, Walter Stovall <walter.stovall@…4309…> wrote:
From what I can tell use of the MetadataTablePrimaryKeyFinder does not matter. The code is still going to hit the test in JDBCFeatureSource.buildFeatureType() that decides to make the feature read-only if there’s a vtable. Fwiw the code was finding my primary key anyway by using Oracle data dictionary info. I had read-only then and now when using a pk metadata table I’m still read-only.
I changed the code and did a successful WFS-T Insert.
My edit changes this:
if(pkey == null || pkey instanceof NullPrimaryKey || virtualTable != null) {
To this:
if(pkey == null || pkey instanceof NullPrimaryKey) {
Sent: Tuesday, May 9, 2017 12:19 PM
To: ‘Andrea Aime’ <andrea.aime@…1268…>
Subject: RE: [Geoserver-devel] Could a “simple” geoserver view become updatable?Yes it gets hit. But it seems like the only thing anything outside that class would call is getPrimaryKey. And that never gets hit.
Sent: Tuesday, May 9, 2017 12:17 PM
Cc: geoserver-devel@lists.sourceforge.netSubject: Re: [Geoserver-devel] Could a “simple” geoserver view become updatable?
Is the MetadataTablePrimaryKeyFinder hit and used?
I’d put breakpoints in it and have a look.
On Tue, May 9, 2017 at 6:13 PM, Walter Stovall <walter.stovall@…4309…> wrote:
I’m having trouble making updatable views work. I have the pk metadata table setup and configured.
Debugging the WFS-T I’m hitting this code in JDBCFeatureSource.buildFeatureType()…
// setup the read only marker if no pk or null pk or it’s a view
boolean readOnly = false;
readOnly = true;
So pkey is setup but the virtualTable != null test then forces it read-only anyway – seems counter to what http://docs.geoserver.org/stable/en/user/data/database/primarykey.html#using-the-metadata-table-with-views says about being able to update views?
Can you suggest anything here?
Walter Stovall
Byers Engineering Company
Sent: Tuesday, May 9, 2017 8:23 AM
Subject: Re: [Geoserver-devel] Could a “simple” geoserver view become updatable?On Tue, May 9, 2017 at 1:30 PM, Walter Stovall <walter.stovall@…4309…> wrote:
My application builds geoserver layers that are based on a “view” as defined by a Oracle SELECT statement pasted into the geoserver layer editor. By using a view my layer becomes read-only, but I want to update via WFS-T transactions.
The configure it accordingly
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
55054 Massarosa (LU)phone: +39 0584 962313
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
