[Geoserver-devel] CoverageDimensionInfo and REST requests
I almost posted this to the user list, but once I figured out the issue this felt more appropriate in the developers’ list … so here I am …
To use the REST interface to update the CoverageDimensionInfo details for a coverage resource … i.e. populate the Coverage Band Details for a coverage layer … it appears that you have to explicitly specify the CoverageDimensionInfo class to get the dimensions list to be properly unmarshalled, like so:
curl -v -u admin:xxxxxx -XPUT -H “Content-type: text/xml” -d “truenewwordwindspeedmps” http://localhost:8080/geoserver/rest/workspaces/arthur/coveragestores/wind/coverages/wind
Otherwise, you get an com.thoughtworks.xstream.mapper.CannotResolveClassException: dimension caused by .
I believe this is handled with the @uml.property name=“dimensions” in
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/catalog/CoverageInfo.java
and similarly in
https://github.com/geoserver/geoserver/blob/2.6.x/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionInfo.java
Not sure, though, as it’s late and I don’t really see a setter for the CoverageDimensionInfo list in CoverageInfo, just a getter.
Should this somehow be set to implicitly handle dimension as members of the dimensions list? Am I just missing how to form the xml for this?
Also, the org.geotools.util.NumberRange is used for the range property, and that seems potentially difficult to deserialize?
While I am on this topic, does anyone know if gsconfig python can handle the coverage dimension settings? I don’t see right away where it handles it, and perhaps it is because of the needed explicit class specification??
Full debug from the request without explicitly specifying the class name:
< HTTP/1.1 500 Internal Server Error
  • Server Apache-Coyote/1.1 is not blacklisted
    < Server: Apache-Coyote/1.1
    < Transfer-Encoding: chunked
    < Date: Thu, 02 Apr 2015 04:14:41 GMT
    < Connection: close
    dimension : dimension
    ---- Debugging information ----
    message : dimension
    cause-exception : com.thoughtworks.xstream.mapper.CannotResolveClassException
    cause-message : dimension
    class : java.util.ArrayList
    required-type : java.util.ArrayList
    converter-type : org.geoserver.config.util.LaxCollectionConverter
    line number : 1
    class[1] : org.geoserver.catalog.impl.CoverageInfoImpl
    converter-type[1] : org.geoserver.config.util.XStreamPersister$CoverageInfoConverter
    version : 1.4.7
  • Closing connection 0
Thanks as always,
Mike Grogan
