Hi Fernando,
thank you for the feedback. Linking GeoTools DEV mailing list since this actually turns out to be related whit GeoTools MongoDB store core.
So if I understood correctly, $or clause is correctly supported since MongoDB 2.6? which was released 5 years ago [1]?
GeoSolutions is using MogoDB driver:
<dependency>
<groupId>org.mongodb</groupId>
<artifactId>mongo-java-driver</artifactId>
<version>3.3.0</version>
<type>jar</type>
<optional>false</optional>
</dependency>
… 3.3.0 is only compatible with MongoDB 2.6 and more recent versions [2].
So +1 one for your suggestion Fernando:
- activate $or support in GeoTools MongoDB store
- add a Java property environment property that would allow the deactivation of the $or operator support, to be on the safe side
Best regards,
[1] https://www.mongodb.com/support-policy
[2] https://docs.mongodb.com/ecosystem/drivers/driver-compatibility-reference/
On Wed, 2019-07-03 at 15:13 +0200, fernando.mino@anonymised.com wrote:
In fact the $or native operator is disabled on Geotools MongoDB module. This is because MongoDB until 2.4.9 version don’t support the mix of $or and spatial indexes very well.
Checking some MongoDB release notes seems like this was improved on 2.6 version:
$or and GeoSpatial Queries
Changed in version 2.6
$or supports geospatial clauses with the following exception for the near clause (near clause includes $nearSphere and $near). $or cannot contain a near clause with any other clause.
So if Geotools MongoDB module starts to support native $or clause by default this could lead to some bugs on previous versions. A good improvement could be a configuration for activating/deactivating native $or.
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
From “groznykh” groznykh.dev@anonymised.com To geoserver-devel@lists.sourceforge.net Cc Date Thu, 20 Jun 2019 09:54:30 -0700 (MST) Subject [Geoserver-devel] CQL filter OR operator does not work on attributes that are multiple on MongoDB DataSource
Hi all
I use GeoServer 2.15 and MongoDB 3.6
I’ve created a collection with data from here https://docs.geoserver.org/stable/en/user/data/app-schema/mongo-tutorial.html (just two records), created 2dsphere index
Then I created a layer from that collection and tried to request it by WMS with cql_filter in URL params.
1. when I use simple attributes (that are not multiple) in the filter all is fine (points are visible):
- filter: “contract.mail” ILIKE ‘%@mail.com%’ OR “name” ILIKE ‘%station%’
- mongo log: { … , filter: { }, projection: { geometry: 1, contact.mail: 1, name: 1 }, … }
http://osgeo-org.1560.x6.nabble.com/file/t385081/stations-stations.png
2. when I use attributes that are multiple in the filter then it DOES NOT work (there is no any point on received PNG):
- filter: “measurements.name” ILIKE ‘%wind%’ OR “measurements.unit” ILIKE ‘%c%’
- mongo log: { … , filter: { }, projection: {geometry: 1, measurements.unit: 1, measurements.name: 1}, … }
http://osgeo-org.1560.x6.nabble.com/file/t385081/stations-stations_(1).png
3. when I change OR to AND in previous filter then it’s works fine:
- filter: “measurements.name” ILIKE ‘%wind%’ AND “measurements.unit” ILIKE ‘%c%’
- mongo log: { …, filter: { $and: [ { measurements.name: /^.wind.$/i }, { measurements.unit: /^.p.$/i } ] }, projection: { geometry: 1 }, … }
http://osgeo-org.1560.x6.nabble.com/file/t385081/stations-stations_(2).png
So I concluded that GeoServer does AND operation by sending filter to mongoDB. And OR operation by itself requesting all records from collection. But with attributes that are multiple something goes wrong. I think it’s a bug.
If you have any sugestions please tell me.
– Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
experts!
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
