[Geoserver-devel] Crazy idea... what about GeoPackage straight in core for 2.12?
I was thinking about the current idea of splitting the geopackage support into several
modules, one store, one WFS output (extension), one WPS output (extension), one WMS output
(community, as written its dangerous for the server stability).
Well, given the importance of the format… what about having the store part as a core component
starting with 2.12? Given it’s an OGC standard, it’s a bridge we’ll have to cross anyways.
Opinions?
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I saw an interesting talk at foss4ge on a proposed extension to geopackage to store sld and ows context in the package as a separate table. This would allow an easy way to migrate a set of styled data from Qgis to geoserver directly.
If we were to implement this having geopackage in core would make it much easier.
Ian
On 26 Jul 2017 19:10, “Andrea Aime” <andrea.aime@anonymised.com> wrote:
Opinions?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
I like the simplification; let’s do it.
On 26 July 2017 at 10:08, Andrea Aime <andrea.aime@anonymised.com> wrote:
Opinions?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Makes sense to me. Can we get it done before the freeze?
Kind regards,
Ben.
On 27/07/17 05:08, Andrea Aime wrote:
into several
one WMS output
Well, given the importance of the format... what about having the store
starting with 2.12? Given it's an OGC standard, it's a bridge we'll have to
cross anyways.
Opinions?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Check out the vibrant tech community on one of the world's most
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
On Thu, Jul 27, 2017 at 1:57 AM, Ben Caradoc-Davies <ben@anonymised.com>
Well, the nice thing is that we really just need to add a dependency to the
store in core
to have a basic setup going.
And maybe a custom panel (reusing the shapefile one) to point have a file
browser
allowing the usage of .gpkg files?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
to cross anyways.
  Opinions?
I worry about the stability of the format. GeoPackage 1.2 isn't actually
approved yet, and the changes from 1.1 are substantive (not just a patch):
https://portal.opengeospatial.org/files/?artifact_id=74224&version=1 for the
release notes.
I think that extension would be better for 2.12 for store, and the outputs
might even be better as remaining in community given the 1.1 -> 1.2
transition.
Brad
the
release notes.
Oh dear... and it will take some time before someone funds support for 1.2
once is out.
However, OGC cannot really expect people to just throw away all the 1.1
geopackages
or suddenly have all software switch to that version no?
The adoption of 1.2 in actual software as the preferred version might take
years, should
we really treat that a concern not to have it as supported?
If it goes like with other specs, by the time one gets some significant
foothold in the market, OGC
has created the N+1 version... it just never ends :-p
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hey Brad / Andrea:
I like the idea of making geopackage core - because it is a good idea.
Brad when someone does have a chance to work on 1.2 is implemented it can start off life as a community module, and move into core when ready. We would need to support both versions right?
On 27 July 2017 at 06:40, Brad Hards <bradh@…4091…> wrote:
to cross anyways.
Opinions?
I worry about the stability of the format. GeoPackage 1.2 isn’t actually
release notes.
might even be better as remaining in community given the 1.1 → 1.2
transition.
Brad
Jody Garnett
+1
We would, but it probably won't be as a community module - its probably a
variation on the geopackage implementation we already have.
My thinking is that we don't want two implementations - users shouldn't need
to know what kind of geopackage they have, they just want to throw it against
the geoserver wall and have it stick in the right place.
Brad
Conditional +1 for making GeoPackage into core. However, before giving a more official status for it I suggest to make sure that geopackage data store supports the use of spatial index in BBOX queries. Otherwise users who try to use big geopackage as datastore for WMS will see suboptimal performance and believe that GeoPackage itself is slow because the service is slow.
I do see code about adding the spatial index support in https://github.com/geotools/geotools/commit/171bfb8931ca2866bd55aa2309770f88c3b37cf4#diff-0adb69381cfbeb460b956e5c794f7051. However, I made a test with GS 2.11 snapshot today and by use experience I feel that spatial index is not really used. I am not sure if logging at Geotools developer level is logging all the SQL because the log shows me just this
2017-08-18 10:48:31,215 DEBUG [org.geotools.rendering] - Querying layer http://www.openplans.org/topp:Jarvi with bbox: ReferencedEnvelope[520694.10973698314 : 529214.8293650263, 7152639.246868316 : 7167382.654399831]
2017-08-18 10:48:31,215 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2017-08-18 10:48:31,216 DEBUG [org.geotools.jdbc] - SELECT "fid","geom" as "geom" FROM "Jarvi"
I suggest developers to have a look at the spatial index and also read http://erouault.blogspot.fi/2017/03/dealing-with-huge-vector-geopackage.html and analyze if suggestion for using JOIN instead of subquery makes sense. I have made some tests with tables which have less than 1 million features and I did not feel a big difference in speed but SQLite does make different query plans for those two. This is the plan with JOIN
SCAN TABLE rtree_ranta10jarvi_geom AS r VIRTUAL TABLE INDEX 2:C0E1C2E3
SEARCH TABLE ranta10jarvi AS t USING INTEGER PRIMARY KEY (rowid=?)
and this is the plan with subquery
SEARCH TABLE ranta10jarvi USING INTEGER PRIMARY KEY (rowid=?)
EXECUTE LIST SUBQUERY 1
SCAN TABLE rtree_ranta10jarvi_geom VIRTUAL TABLE INDEX 2:C0E1C2E3
Geoserver should require that spatial tables have R-Tree indexes and create them if they are missing. It will be harder to handle views, see https://github.com/opengeospatial/geopackage/issues/207. In simple cases views can be handled and QGIS knows how to do it http://osgeo-org.1560.x6.nabble.com/gdal-dev-GeoPackege-views-and-spatial-index-td5312752.html.
-Jukka Rahkonen-
________________________________________
Lähettäjä: Brad Hards <bradh@anonymised.com>
Lähetetty: 18. elokuuta 2017 1:14
Vastaanottaja: 'Jody Garnett'
Kopio: 'Geoserver-devel'; 'Andrea Aime'
Aihe: Re: [Geoserver-devel] Crazy idea... what about GeoPackage straight in core for 2.12?
+1
Brad
