Hi
I'm following the "Creating a WFS Output Format" tutorial [1] to create a new wfs output format but struggling a bit at step 4: Eclipse throws some errors in the import section since the org.opengis.feature.simple classes cannot be resolved/imported. Do I have to add them somehow?
[1]: http://geoserver.org/display/GEOSDOC/Creating+a+WFS+Output+Format
regards
Stefan
mit freundlichem Gruss
Stefan Ziegler
Hi Stefan,
The geoapi dependency *should* be getting dragged in transitively. Although i guess depending on your local maven repository it might not be.
What version of the archetype are you using? I just tweaked the resulting pom in svn to add the opengeo repository to the resulting pom. That might fix the problem. Are you running from svn? If so can you update. If not i can send you an updated archetype jar.
-Justin
Ziegler Stefan wrote:
Hi
regards
Stefan
Stefan Ziegler
Come build with us! The BlackBerry® Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
