[Geoserver-devel] create wfs output format
Hi Justin
thanks so far. I try to find some wifi here in the office to use my notebook. In the meantime one more question: How does the mvn archetype:create command knows where to look for the appropriate archetype which is somewhere on my local machine? I don't see any reference between <geoserver_checkout> and <somewhere_else> directories.
regards
Stefan
mit freundlichem Gruss
Stefan Ziegler
----- Originalnachricht -----
Von: Justin Deoliveira <jdeolive@anonymised.com>
Gesendet: Fre, 2.10.2009 14:20
An: Ziegler Stefan <Stefan.Ziegler@anonymised.com>
Cc: geoserver-devel@lists.sourceforge.net
Betreff: Re: [Geoserver-devel] create wfs output format
Hi Stefan,
So yeah, what i am suggesting is you do the following:
1) update from svn (1.7.x or 2.0.x, your choice)
2) do a full geoserver build (this will include the new archetype)
3) change the archetype version to 1.7.7-SNAPSHOT or 2.0-SNAPSHOT
(whichever version you choose to use)
To verify i deleted all local jars for geoserver, geotools, and geoapi
from my local repository and did the following:
cd <geoserver_checkout>/src
mvn clean install
cd <somewhere else>
mvn archetype:create -DarchetypeGroupId=org.geoserver.maven \
    -DarchetypeArtifactId=geoserver-archetype-wfsoutputformat \
    -DarchetypeVersion=1.7.7-SNAPSHOT -DgroupId=org.geoserver \
    -DartifactId=csv
cd csv
mvn eclipse:eclipse
I then loaded the csv project into eclipse with no problems.
Hope that helps.
-Justin
Ziegler Stefan wrote:
Hi Justin
I tried to use the version written in the tutorial (1.7.0.-SNAPSHOT). The maven archedtype:create command ends with the following error:
[ERROR] BUILD ERROR
[INFO] Error creating from archetype
Embedded error: org.apache.maven.archetype.downloader.DownloadNotFoundException: Requested download does not exist.
Unable to determine the release version
Try downloading the file manually from the project website.
Then, install it using the command:
    mvn install:install-file -DgroupId=org.geoserver.maven -DartifactId=geoserver-archetype-wfsoutputformat -Dversion=RELEASE -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
    mvn deploy:deploy-file -DgroupId=org.geoserver.maven -DartifactId=geoserver-archetype-wfsoutputformat -Dversion=RELEASE -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  org.geoserver.maven:geoserver-archetype-wfsoutputformat:jar:RELEASE
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: Error creating from archetype
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:583)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeStandaloneGoal(DefaultLifecycleExecutor.java:512)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:482)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:330)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:227)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:142)
    at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:336)
    at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
    at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
    at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
    at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
    at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
    at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.MojoExecutionException: Error creating from archetype
    at org.apache.maven.archetype.mojos.MavenArchetypeMojo.execute(MavenArchetypeMojo.java:241)
    at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:451)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:558)
    ... 16 more
Caused by: org.apache.maven.archetype.exception.UnknownArchetype: org.apache.maven.archetype.downloader.DownloadNotFoundException: Requested download does not exist.
    at org.apache.maven.archetype.common.DefaultArchetypeArtifactManager.getArchetypeFile(DefaultArchetypeArtifactManager.java:117)
    at org.apache.maven.archetype.old.DefaultOldArchetype.createArchetype(DefaultOldArchetype.java:119)
    at org.apache.maven.archetype.mojos.MavenArchetypeMojo.execute(MavenArchetypeMojo.java:230)
    ... 18 more
Caused by: org.apache.maven.archetype.downloader.DownloadNotFoundException: Requested download does not exist.
    at org.apache.maven.archetype.downloader.DefaultDownloader.download(DefaultDownloader.java:63)
    at org.apache.maven.archetype.common.DefaultArchetypeArtifactManager.getArchetypeFile(DefaultArchetypeArtifactManager.java:98)
    ... 20 more
Caused by: org.apache.maven.artifact.resolver.ArtifactNotFoundException: Unable to determine the release version
    at org.apache.maven.artifact.transform.ReleaseArtifactTransformation.transformForResolve(ReleaseArtifactTransformation.java:53)
    at org.apache.maven.artifact.transform.DefaultArtifactTransformationManager.transformForResolve(DefaultArtifactTransformationManager.java:57)
    at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:129)
    at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:74)
    at org.apache.maven.archetype.downloader.DefaultDownloader.download(DefaultDownloader.java:55)
    ... 21 more
[INFO] Total time: 4 seconds
[INFO] Finished at: Thu Oct 01 19:20:28 CEST 2009
[INFO] Final Memory: 9M/81M
So I used -DarchetypeVersion=1.7.0 which was the only one without getting the error. I build GeoServer from SVN and found some wfs-outputformat-2.0.jar (can't remember the precise name of the jar). Can I force maven to use this one instead (you see I'm really not familiar with this maven stuff :-)).
regards
Stefan
Stefan Ziegler
Gesendet: Don, 1.10.2009 15:05
Hi Stefan,
The geoapi dependency *should* be getting dragged in transitively.
Although i guess depending on your local maven repository it might not be.
What version of the archetype are you using? I just tweaked the
resulting pom in svn to add the opengeo repository to the resulting pom.
That might fix the problem. Are you running from svn? If so can you
update. If not i can send you an updated archetype jar.
-Justin
Hi
I'm following the "Creating a WFS Output Format" tutorial [1] to create a new wfs output format but struggling a bit at step 4: Eclipse throws some errors in the import section since the org.opengis.feature.simple classes cannot be resolved/imported. Do I have to add them somehow?
[1]: http://geoserver.org/display/GEOSDOC/Creating+a+WFS+Output+Format
regards
Stefan
Stefan Ziegler
Come build with us! The BlackBerry&reg; Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
http://p.sf.net/sfu/devconf
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Stefan,
No problem. Hope you are making progress :slight_smile:
Hi Justin
Basically, it will local in your local maven repository. Usually in your home directory under .m2/repository.
WHen you specify:
It will look in the directory:
<HOME>/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/1.7.7-SNAPSHOT
Now, let's say you don't have it installed locally. What will happen is:
a) if you are running the archetype from an existing maven project (ie a directory that has a pom.xml), it will use any repositories defined in the pom.xml.
b) if you are not running the archetype from an existing project it will use the default public maven repository (http://repo1.maven.org/maven2/).
So to sum up, in the wfs output format tutorial the first step is to build geoserver, which will put the archetype in the local repository. Unfortunately the version on the wiki is old, and it references an old version.
Hope that helps.
-Justin
regards
Stefan
Stefan Ziegler
Hi Stefan,
3) change the archetype version to 1.7.7-SNAPSHOT or 2.0-SNAPSHOT (whichever version you choose to use)
To verify i deleted all local jars for geoserver, geotools, and geoapi from my local repository and did the following:
mvn clean install
cd <somewhere else>
    -DartifactId=csv
cd csv
mvn eclipse:eclipse
Hope that helps.
-Justin
Hi Justin
[ERROR] BUILD ERROR
Then, install it using the command: mvn install:install-file -DgroupId=org.geoserver.maven -DartifactId=geoserver-archetype-wfsoutputformat -Dversion=RELEASE -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId=org.geoserver.maven -DartifactId=geoserver-archetype-wfsoutputformat -Dversion=RELEASE -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
[INFO] Trace
    ... 16 more
    ... 18 more
    ... 20 more
    ... 21 more
regards
Stefan
Stefan Ziegler
Hi Stefan,
The geoapi dependency *should* be getting dragged in transitively. Although i guess depending on your local maven repository it might not be.
What version of the archetype are you using? I just tweaked the resulting pom in svn to add the opengeo repository to the resulting pom. That might fix the problem. Are you running from svn? If so can you update. If not i can send you an updated archetype jar.
-Justin
Hi
regards
Stefan
Stefan Ziegler
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
Justin Deoliveira
