There should be two options for creating a new feature type via the REST api:
1) POST /rest/workspaces/<ws>/datastores/<store>/featureTypes
Where the content must contain the name of the feature type, along with all the other information about attributes
or:
2) PUT to /rest/workspaces/<ws>/datastores/<store>/featureTypes/<ftName>
Where the content contains optionally the feature type name, along with all the other information about attributes
Looked over the patch and a few comments:
* When throwing exceptions it is best to throw a RestletException and pass in a status code, else the client will just receive a 500 (server internal error). But for the validation cases in FeautreTypeResource.buildFeatureType() it is more appropriate to send back an error relaying that the client did not specify the request properly. Probably a 400 or something.
* Rename XStreamPersister.setHideAttributes() to something more descriptive of being applicable only to feature types, setHideFeatureTypeAttributes() or something.
* I see some dead code in the patch for XStreamPersister? doUnmarshal()
* The change to ResourcePool:
- if (info.getAttributes() != null && !info.getAttributes().isEmpty()) {
+ if (info.getAttributes() != null && !info.getAttributes().isEmpty() && info.getAttributes().get(0).getBinding() != null) {
Can you explain the rationale here?
Also a heads up. One of the pains of xstream is adding new properties to an object but also dealing with old representations of it on disk. Since xstream does not use the default constructor any newly defined attributes that are not in a representation will always be set to null regardless of what the default constructor does.
So in this case when reading older configurations AttributeTypeINfo.getBInding() and getLength() will result in null. Perhaps this is ok... but it might be wise to implement AttributeTypeInfoImpl.readResolve() to initialize them to sensible defaults.
Nice work on the patch. A very cool feature.
-Justin
On 3/23/10 1:04 PM, Andrea Aime wrote:
I have a first patch for the above attached to
http://jira.codehaus.org/browse/GEOS-3872
I think I need a clarification though. I though we were
going to post to a feature type description to:
but as far as I can see DataStoreResource already handles
post and it does for the creation of a new store... I guess
the stores list delegates to it for the post handling somehow.
So I added the creation code into FeatureTypeResource.
The latter was already managing POST with the assumption
the feature type was already in the store and just needed
to be published, with the patch it will first look to see
if it's there, if not, it will create it and then
configure it.
I see how this can be troublesome though, a typo in the
feature type name post-ed and an attempted configuration
will turn into the creation of a new feature type
(well, sort of, it will fail anyways you did not specify any
attribute list).
However, if it's considered more desirable to post directly
to the store resources, what other changes are necessary?
PS: I know the previous mails talked about a bigger
change, but since this is low priority work that is
done only when I have nothing else to do I'd prefer
to start commiting smaller, self contained patches that
add one bit of the overall plan at a time.
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
