Hi Devs,
Testing here a Windows setup with an ecw-store (via gdal plugin), which
is epsg:28992. Serving layers of this store is ok, we can serve as 28992
or 3857 but NOT epsg:4326.
So reprojecting to 4326 fails with a timeout. Both small and large ecw's.
Running jre 1.8.0_172
Full logs below show:
Unable to create a granuleDescriptor
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer@anonymised.com
due to jai scale bug
Anybody an idea if changing java on that server should fix this?
The server had memory problems sometimes, and one of the theories was
that it was because of those failing 4326 request.
But we do not have real evidence for it yet.
Richard Duivenvoorde
Request: getServiceInfo
2018-10-23 14:16:13,623 DEBUG [org.geotools.util] - CRSConverterFactory
can be applied from Strings to CRS only.
InterpolationConverterFactory can be applied from Strings to
Interpolation only.
Interpolation only.
2018-10-23 14:16:13,623 DEBUG [org.geotools.styling] - number of fts set 1
2018-10-23 14:16:13,623 INFO [org.geoserver.wms] -
Request: getLegendGraphic
BaseUrl = http://localhost:8080/geoserver/
Env = {}
Exceptions = SE_XML
FeatureType = null
Format = image/png
Get = false
Height = 20
Kvp = {REQUEST=GetLegendGraphic, FORMAT=image/png, SLD_VERSION=1.1.0,
VERSION=1.3.0, STYLE=, SERVICE=WMS, WIDTH=20, HEIGHT=20,
LAYER=KvS_1988_80cm, TRANSPARENT=true}
Layers = [SimpleFeatureTypeImpl http://www.opengis.net/gml:GridCoverage
identified extends Feature(geom:geom,grid:grid,params:params)]
LegendOptions = {}
Legends = [LegendRequest [layer=Lufo:KvS_1988_80cm,
name=http://www.opengis.net/gml:GridCoverage styleName=null, title=Kop
van Schouwen 1988 80cm, legendInfo=null]]
Locale = null
RawKvp = {REQUEST=GetLegendGraphic, FORMAT=image/png,
SLD_VERSION=1.1.0, VERSION=1.3.0, STYLE=, SERVICE=WMS, WIDTH=20,
HEIGHT=20, LAYER=Lufo:KvS_1988_80cm, TRANSPARENT=true}
Request = GetLegendGraphic
RequestCharset = null
Rules = [null]
Scale = -1.0
Strict = true
Styles = [StyleImpl[ name=raster]]
Transparent = true
Version = 1.3.0
Width = 20
Wms = org.geoserver.wms.WMS@anonymised.com
2018-10-23 14:16:13,669 INFO [org.geoserver.wms] -
2018-10-23 14:16:13,669 DEBUG [org.geotools.util] - CRSConverter:
Converting object of class java.lang.String to
org.opengis.referencing.crs.CoordinateReferenceSystem
2018-10-23 14:16:13,669 DEBUG [org.geotools.util] - CRSConverterFactory
Interpolation only.
Interpolation only.
2018-10-23 14:16:13,669 DEBUG [org.geotools.coverageio.gdal.ecw] -
Creating a new ECWFormat.
2018-10-23 14:16:13,669 TRACE [org.geotools.factory] - ENTRY
(GridCoverageFactory)
2018-10-23 14:16:13,669 TRACE [org.geotools.factory] - RETURN
(GridCoverageFactory): found implementation Optional.
[org.geotools.renderer.lite.gridcoverage2d] - Rendering using
interpolation javax.media.jai.InterpolationNearest@anonymised.com
(CoordinateOperationFactory, COORDINATE_OPERATION_FACTORY)
(CoordinateOperationFactory, COORDINATE_OPERATION_FACTORY): found
2018-10-23 14:16:13,669 DEBUG [org.geotools.coverageio] - Adjusted
Requested Envelope = ReferencedEnvelope[35016.0 : 46544.0,
408465.6000000001 : 420779.20000000007]
Requested raster dimension =
java.awt.Rectangle[x=-10,y=-10,width=21,height=21]
Corresponding raster source region =
java.awt.Rectangle[x=0,y=0,width=14410,height=15392]
2018-10-23 14:16:13,716 DEBUG [org.geotools.coverageio] - Coverage read:
width = 22 height = 22
2018-10-23 14:16:13,716 DEBUG [org.geotools.coverageio.gdal.ecw] -
2018-10-23 14:16:13,763 TRACE [org.geotools.factory] - ENTRY
2018-10-23 14:16:13,763 TRACE [org.geotools.factory] - RETURN
2018-10-23 14:16:13,763 DEBUG
[org.geotools.referencing.operation.transform] - Optimizing the warp
into an affine transformation: AffineTransform[[1.022506992525824,
-0.026102642728077, 0.012007293130225], [0.021801669884641,
1.020763038529749, -0.469384520710605]]
2018-10-23 14:16:13,763 DEBUG [org.geotools.coverage.processing] -
Resampled coverage "B8271_Kop_Van_Schouwen_1988" from coordinate system
"Amersfoort / RD New" (for an image of size 22×22) to coordinate system
"WGS 84" (image size 22×22). JAI operation is "Warp" with "Nearest"
interpolation on geophysics pixels values. Background value is (0, 0, 0).
[org.geotools.renderer.lite.gridcoverage2d] - Reprojecting to crs
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]]
2018-10-23 14:16:13,779 DEBUG
[org.geotools.renderer.lite.gridcoverage2d] - Unable to create a
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
granuleDescriptor
2018-10-23 14:16:13,779 INFO [org.geoserver.wms] -
Request: getMap
Angle = 0.0
Bbox = SRSEnvelope[3.205312338616155 : 423999.99999999994,
0.1167809869355378 : 84000.0]
BgColor = java.awt.Color[r=255,g=255,b=255]
Buffer = 0
CQLFilter = null
Crs = GEOGCS["WGS 84",
Elevation =
Env = {}
Exceptions = SE_XML
FeatureId = null
FeatureVersion = null
Filter = null
Filters = null
Format = image/png
FormatOptions = {DPI=120}
Get = true
Height = 527
Interpolations =
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Palette = null
RawKvp = {CRS=EPSG:4326, FORMAT=image/png, MAP_RESOLUTION=120, STYLES=,
WIDTH=105, HEIGHT=527, LAYERS=Lufo:KvS_1988_80cm, REQUEST=GetMap,
BBOX=3.205312338616154832,0.1167809869355378033,423999.9999999999418,84000,
FORMAT_OPTIONS=dpi:120, VERSION=1.3.0, SERVICE=WMS, DPI=120,
TRANSPARENT=TRUE}
RemoteOwsType = null
RemoteOwsURL = null
Request = GetMap
RequestCharset = UTF-8
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = urn:ogc:def:crs:EPSG:4326
StartIndex = null
StyleBody = null
StyleFormat = sld
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time =
Transparent = true
ValidateSchema = false
Version = 1.3.0
ViewParams = null
Width = 105
2018-10-23 14:16:13,779 DEBUG [org.geotools.styling] - number of fts set 1
2018-10-23 14:16:14,999 INFO [org.geoserver.wms] -
