I notice that http://gridlock.opengeo.org/geoserver/2.1.x/community-latest/ and http://gridlock.opengeo.org/geoserver/trunk/community-latest/ no longer include download links to the CSS community module. Can anyone give me a clue why it has disappeared? As it stands the CSS tutorial in the manual points to a file listing which doesn’t include the module.
Thanks in advance.
David Winslow
OpenGeo - http://opengeo.org/
Its release descriptor is currently commented out. I think this was because at one point it was not building properly. Looks like it is still enabled in the profile though.
http://svn.codehaus.org/geoserver/trunk/src/community/pom.xml
Search for “ext-css.xml”. Please reenable if the module is good to go.
On Tue, Feb 15, 2011 at 6:15 PM, David Winslow <dwinslow@anonymised.com> wrote:
Thanks in advance.
David Winslow
The ultimate all-in-one performance toolkit: Intel(R) Parallel Studio XE:
Pinpoint memory and threading errors before they happen.
Find and fix more than 250 security defects in the development cycle.
Locate bottlenecks in serial and parallel code that limit performance.
http://p.sf.net/sfu/intel-dev2devfeb
Geoserver-devel mailing list
Justin Deoliveira
The CSS module builds fine for me locally so I have re-enabled it. Thanks for the pointer. I’m kicking off and watching a hudson build to make sure things work there as well.
David Winslow
On Tue, Feb 15, 2011 at 8:31 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Thanks in advance.
David Winslow
Justin Deoliveira
