as you may know GeoServer now supports styling in languages other than
SLD, provided that there is a StyleHandler implementation that knows how
to parse the new language and turn it into a StyledLayerDescriptor object,
a Java in memory representation of a SLD sheet.
The current CSSHandler implementation does the CSS parsing and translation
on the fly, without saving any SLD of the result.
In theory this is nice and clean, in practice it’s highly problematic for complex
styles, as it might take a lot of time.
So, I want to change the CSSHandler so write the SLD to disk, and use it as
a translation cache, instead (the style will be re-translated if the SLD gets out of date).
This should also care for those that want to see how the CSS to SLD tranlsation
was performed (as it’s tricky business, sometimes you really want to know
what the heck is going on with the map rendering results, or the results of
a call to GetLegendGraphic).
Feedback welcomed.
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
