Hi guys,
I’m having some troubles in building community modules.
I have noticed that community/release/pom.xml has this entry
org.geoserver.community
css
${project.version}
whilst it seems that css isn’t a community module anymore (talking with Andrea, it should be an extension right?)
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Yes. I had some troubles with Git when I was moving things around, this is probably part of the collateral damage. (I already had to fix an issue where there was no source code for the extension module!)
If you remove it and the build succeeds please commit, otherwise I can investigate this issue later today.
On Tue, Aug 13, 2013 at 10:57 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi guys,
css
${project.version}
Daniele
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It’s a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
