[Geoserver-devel] CSSDemoPage may create the sld file before a CatalogAddEvent is fired
I’m working with a plugin that implements a CatalogListener to handle the incoming CatalogAddEvent.
This implementation works fine with the event generated from:
org.geoserver.wms.web.data.StyleNewPage.onStyleFormSubmit()
which writes the SLD to the FileSystem then fire the event.
Using the CssDemoPage when I try to create the css the event is fired but the file does not exists on the FileSystem.
Looking at the CssDemoPage.createCssTemplate() the patch seems quite simple so I propose the following pull req:
https://github.com/geoserver/geoserver/pull/576
Let me know if it is acceptable for you.
Carlo
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK for more information.
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
Looks like it has already been accepted :slight_smile:
Jody Garnett
On Thu, May 1, 2014 at 2:22 AM, carlo cancellieri <carlo.cancellieri@anonymised.com> wrote:
Carlo
@cancellieric
Software Engineer
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-devel mailing list
