[Geoserver-devel] CSW and checking spatial filters
as you may know a CSW should check the GetRecord incoming filters for validity, one of
the checks we do is verify that spatial filters are actually hitting spatial properties.
The current code uses a SpatialFilterChecker which works fine for the csw:Record case,
and I guess is working fine for the ISO case too, but it’s definitely not working as expected
for the more complex ebRIM case, where the geometries are nested in a structure
that looks a lot like a hashmap, whose keys are what determine which type of value
should be contained in the properties (long story short, having just the schema won’t cut it).
So I wanted to change things and have the code delegate the check to RecordDescriptor:
RecordDescriptor {
  • Checks the spatial filters, throws service exceptions in case they are referring to non existing,
  • or existing but non spatial, properties
    public void verifySpatialFilters(Filter filter);
and have the common cases use SpatialFilterChecker to implement the above method.
I’d like to commit the change on trunk only, no need to backport to 2.4.x
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Sounds reasonable to me but I will let Niels chime in.
Regarding the backport is there a reason not to backport it to 2.4.x? Thinking it is best to not diverge unless the code on master is unstable (which doesn’t seem to be the case here) so that future backports remain trivial.
$0.02
On Thu, Aug 22, 2013 at 1:48 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
RecordDescriptor {
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Introducing Performance Central, a new site from SourceForge and
AppDynamics. Performance Central is your source for news, insights,
analysis and resources for efficient Application Performance Management.
Visit us today!
http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Thu, Aug 22, 2013 at 9:18 PM, Justin Deoliveira <jdeolive@anonymised.com>wrote:
(which doesn't seem to be the case here) so that future backports remain
trivial.
Uh, mostly because it's an API change (new method in an interface), but
generally speaking for the existing code it's a clean refactor
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Sounds good to me.
Regarding the backport is there a reason not to backport it to 2.4.x? Thinking it is best to not diverge unless the code on master is unstable (which doesn't seem to be the case here) so that future backports remain trivial.
$0.02
On Thu, Aug 22, 2013 at 1:48 PM, Andrea Aime <andrea.aime@anonymised.com <mailto:andrea.aime@anonymised.com>> wrote:
    and I guess is working fine for the ISO case too, but it's
    in a structure
    which type of value
    just the schema won't cut it).
    RecordDescriptor {
       * Checks the spatial filters, throws service exceptions in case
       * or existing but non spatial, properties
    the above method.
    I'd like to commit the change on trunk only, no need to backport
    to 2.4.x
    Opinions?
    Ing. Andrea Aime
    @geowolf
    Technical Lead
    phone: +39 0584 962313 <tel:%2B39%200584%20962313>
    fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
    mob: +39 339 8844549 <tel:%2B39%20%C2%A0339%208844549>
    Management.
    Visit us today!
    <mailto:Geoserver-devel@lists.sourceforge.net>
Justin Deoliveira
Visit us today!
trivial.
Here is the patch applied on trunk:
https://github.com/geoserver/geoserver/commit/01843f8be22e7e30ea1acc77e3bb2de72a552f14
So, shall I backport it to 2.4.x? (no particular objection to the backport
from me, CSW just graduated
and we don't have a release with it included in the wild)
information.
Ing. Andrea Aime
@geowolf
Technical Lead
I would say given that we haven’t officially released it yet I would be +1 on backporting the api change in the interest of keeping the two branches consistent.
On Fri, Aug 23, 2013 at 7:06 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Aug 22, 2013 at 9:18 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Justin Deoliveira
So, shall I backport it to 2.4.x? (no particular objection to the backport from me, CSW just graduated
and we don’t have a release with it included in the wild)
Ing. Andrea Aime
@geowolf
Technical Lead
