[Geoserver-devel] CSW did not make it into extension by RC1
I was looking at the release notes and noticed that CSW is not yet in extension despite
the positive vote for the associated GSIP
Do you think it will make it by RC2?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Yes, a pull request has just been made for this:
https://github.com/geoserver/geoserver/pull/299
Kind Regards
Niels
On 18/08/13 14:52, Andrea Aime wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It's a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
On Mon, Aug 19, 2013 at 4:08 PM, Niels Charlier <niels@anonymised.com> wrote:
I believe you'll have to make one for 2.4.x too, which was branched off
yesterday.
At this point it should just be a cherry-pick away
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Done https://github.com/geoserver/geoserver/pull/300
On 19/08/13 16:15, Andrea Aime wrote:
On Mon, Aug 19, 2013 at 4:08 PM, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
I believe you'll have to make one for 2.4.x too, which was branched off yesterday.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Niels,
this pull request was merged on master yesterday and today we have the
results of
the nightly build.
As far as I can see there are issues with the zip contents:
http://gridlock.opengeo.org/geoserver/trunk/ext-latest/geoserver-2.5-SNAPSHOT-csw-plugin.zip
It contains a test jar that probably should not be there, and lacks the
jars for the csw extension
altogether
information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Aug 20, 2013 at 2:35 PM, Andrea Aime
<andrea.aime@anonymised.com>wrote:
Hi Niels,
results of
the nightly build.
altogether
Btw, if you want to make changes and try locally, you can do the following:
* cd release
* mvn clean install -nsu
* cd ..
* mvn assembly:attached
and then check the results in target/release.
From a cursory look, you did not make the release module depend on the csw
ones,
so their jars are not in the right place when assembly:attached builds the
zip files.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Yes you were right, sorry about that, a fix has been pull requested. 2.4.x request updated. Cheers Niels
On 20/08/13 14:37, Andrea Aime wrote:
On Tue, Aug 20, 2013 at 2:35 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Niels,
this pull request was merged on master yesterday and today we have the results of
the nightly build.
It contains a test jar that probably should not be there, and lacks the jars for the csw extension
altogether
  • cd release
  • mvn clean install -nsu
  • cd …
  • mvn assembly:attached
From a cursory look, you did not make the release module depend on the csw ones,
so their jars are not in the right place when assembly:attached builds the zip files.
On Tue, Aug 20, 2013 at 10:48 PM, Niels Charlier <niels@anonymised.com> wrote:
had a quick look at the extension, now it contains a number of packaged
schemas normally
used for app-schema. I guess they are needed for the ISO mappings?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Aug 22, 2013 at 6:16 PM, Andrea Aime
schemas normally
Ah, just noticed that CSW was not getting build with a -Prelease build,
just fixed it on trunk:
https://github.com/geoserver/geoserver/commit/c25da2ebca987688fb52d0228fa52be8ab4e4154
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Yes, the feature types are automatically generated from the xsd files so they all need to be present. Cheers Niels
had a quick look at the extension, now it contains a number of packaged schemas normally
On Thu, Aug 22, 2013 at 6:42 PM, Niels Charlier <niels@anonymised.com> wrote:
schemas normally
Very good then, just merged on 2.4.x as well.
I'm going to make a little bug fix in the DescribeRecordResponse schema
location (lacks a /),
so I guess I can backport the other commit I did as well
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Thank you, Andrea
On 22/08/13 18:47, Andrea Aime wrote:
On Thu, Aug 22, 2013 at 6:42 PM, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
I'm going to make a little bug fix in the DescribeRecordResponse schema location (lacks a /),
Ing. Andrea Aime
@geowolf
Technical Lead
