Using aditional CRS's which are specified in a user file with the help
of the -Duser.projections.file property doesn't seem to work as
expected.
The user's WKT definitions are listed in srsHelp.do, but when
requesting a map, the following exception is thrown:
88321 [SEVERE] org.vfny.geoserver.servlets.AbstractService - Service
exception occurred
org.vfny.geoserver.wms.WmsException: No code "EPSG:41110" from
authority "European Petroleum Survey Group" found for object of type
"CoordinateReferenceSystem".
at org.vfny.geoserver.wms.requests.GetMapKvpReader.parseOptionalParameters(GetMapKvpReader.java:237)
at org.vfny.geoserver.wms.requests.GetMapKvpReader.getRequest(GetMapKvpReader.java:202)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:299)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:619)
Example request:
http://localhost:8080/geoserver/wms?bbox=-2579378,-2416659,2674993,2394577&styles=polygon&Format=image/png&request=GetMap&layers=topp:states&width=800&height=600&srs=EPSG:41110
Any ideas?
Alex
expected.
That has been reported by a number of sources... unfortunately
I got moved to WFS-versioned so I did not spend time investiganting
why... I may try tomorrow morning, since I'm a little stuck on
wfs-versioned anyways...
It works if the FactoryUsingWKT extends the EPSGCRSAuthorityFactory
Alex
Using that breaks everything. EPSGCRSAuthorityFactory sets itself
as authority with most precedence, so it's the first one to answer,
and basically overrides all HSQL crs, included all TOWGS84 information.
Hi Alex,
What is the WKT of your project. I can add it to my properties file and
give it a shot. Or is there another projection in the properties file
in svn that has the same issue?
-Justin
Alex
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
!DSPAM:1004,45e5c2fa213692051017194!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
expected.
Ok, I traced this down to two interacting bugs. I solved the first,
the second (http://jira.codehaus.org/browse/GEOT-1175) is still there but should not trigger anymore after my changes for GEOS-905.
Long story short, this should be working ok now on 1.5.x and on trunk too.
Alex, Cedric, you both have been hit by this. Can you double check everything is working as expected?
I will give it a shot--thanks Andrea
Alex
> expected.
Custom SRS stuff works--mwahahahaaaaaa....
Thanks Andrea
Alex
Alex
> > expected.
> Cheers
> Andrea
Thanks Andrea
Alex
Thanks Andrea.
The crs EPSG:41001, which can be found in the epsg-extension jar of Geotools, that I use for a NetCDF file, is now correctly usable in Geoserver
Thanks for fixing this issue
Cédric B.
Alex
> > expected.
> Cheers
> Andrea
