On Thu, May 28, 2015 at 11:48 AM, nickfx <teslabyte@anonymised.com> wrote:
Hi Andrea,
thanks for your reply. I actually would like to write my own code for the
calculations. Thats why I cant use the existing process. So I was wondering
what the best way to create my own Heatmap process would look like.
I guess the easiest way would be to make your process implement
GeoServerProcess,
and register it in the application context, it will show up in the gs
process
group.
Here is an example and some references:
https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/PagedUniqueProcess.java
https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/main/java/applicationContext.xml#L201
https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GeoServerProcess.java
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
