[Geoserver-devel] Cycle
Hi, I am getting a "cyclic reference" could someone help, it driving me crazy :cry:
C:\projects\1.4.x>mvn compile
[INFO] Scanning for projects...
[INFO] ----------------------------------------------------------------------------
[ERROR] BUILD FAILURE
[INFO] The projects in the reactor contain a cyclic reference: Edge between 'Vertex{label='org.openplans:geoserver'}' an
d 'Vertex{label='org.openplans:geoserver'}' introduces to cycle in the graph org.openplans:geoserver --> org.openplans:g
eoserver
[INFO] Total time: < 1 second
[INFO] Finished at: Fri Mar 31 09:38:52 CAT 2006
[INFO] Final Memory: 1M/2M
eoserver
Hi Clint,
I had a quick look and I think this is happening because in the root pom.xml file, there is a dependency:
  <dependency>
             <groupId>org.openplans</groupId>
             <artifactId>geoserver</artifactId>
               <version>1.0-SNAPSHOT</version>
               <type>jar</type>
               <scope>compile</scope>
           </dependency>
Which makes this pom dependent on itself if you dont have a jar in the repository. Can you explain the purpose of this dependency?
-Justin
eoserver
This SF.Net email is sponsored by xPML, a groundbreaking scripting language
that extends applications into web and mobile media. Attend the live webcast
and join the prime developer group breaking into this new coding territory!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=110944&bid=241720&dat=121642
Geoserver-devel mailing list
Hi Justin,
You were write I dont need that dependancy, it must have slipped in by mistake :-[ so I removed it and "booom :slight_smile: " cyclic reference gone..
Thanks again..
Justin Deoliveira wrote:
Hi Clint,
<dependency>
              <type>jar</type>
          </dependency>
-Justin
eoserver
