[Geoserver-devel] Data.getFeatureTypeInfos() semantics changed on trunk?
trying to get a capabilities on trunk today I got this
stack trace:
05 giu 15:57:47 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wfs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:62)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:617)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:194)
  at
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
  at org.geoserver.wfs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:60)
  ... 55 more
Caused by: java.lang.IllegalStateException: This featureType is not enabled
  at org.vfny.geoserver.global.FeatureTypeInfo.getNameSpace(FeatureTypeInfo.java:675)
  at org.geoserver.wfs.CapabilitiesTransformer$WFS1_1$CapabilitiesTranslator1_1.featureType(CapabilitiesTransformer.java:1235)
  at org.geoserver.wfs.CapabilitiesTransformer$WFS1_1$CapabilitiesTranslator1_1.featureTypeList(CapabilitiesTransformer.java:1138)
  at org.geoserver.wfs.CapabilitiesTransformer$WFS1_1$CapabilitiesTranslator1_1.encode(CapabilitiesTransformer.java:826)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
  ... 57 more
This is happening because the catalog is now returning a non enabled feature type. The old catalog did not load the disabled feature types at
all.
The new one does, and it makes some sense, since it has to be both
live catalog and "config", whilst in the old code the non enabled
feature type could be kept seperate in the config objects.
Now, I can add some filtering in Data for the moment to restore the
old behaviour (which is probably needed for coverages as well, did
not check), but in the long run we'll have to change the client
code to account for this.
Opinions on how to proceed?
