Hi there,
I’ve sorted out a problem with configuring the info.xml file for an Oracle data source for a feature so that Geoserver starts up without any problems when you start up Tomcat. However, now when I go to do a GetCapabilities or GetFeature request I get an exception reported from Tomcat. The essential part of the error message appears to be this (the entire error stack is included below):
Caused by: java.lang.IllegalStateException: The server configuration has not been loaded yet
at org.vfny.geoserver.config.ServerConfig.getInstance(ServerConfig.java:190)
at org.vfny.geoserver.servlets.Dispatcher.
... 35 more
The error is definitely caused by the new feature type because when I remove that feature type directory from the geoserver/data directory, the GetCapabilities request works (and so does GetFeature for the example shape files).
The directory under geoserve/data is FISPATIAL and the inof.xml file looks like this
<?xml version="1.0" encoding="UTF-8"?>FISPATIAL
Fluid InclusionsThese are fluid inclusions
geology
4283
Anyone got an idea of what’s going on?
Stuart
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Error instantiating servlet class org.vfny.geoserver.servlets.wfs.WfsDispatcher
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:912)
at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:668)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2415)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180)
at org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:171)
at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:172)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:223)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:594)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:392)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:565)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:619)
at java.lang.Thread.run(Thread.java:534)
root cause
java.lang.ExceptionInInitializerError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:274)
at java.lang.Class.newInstance0(Class.java:308)
at java.lang.Class.newInstance(Class.java:261)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:903)
... 35 more
