[ERROR] Failed to execute goal on project gs-ows: Could not resolve dependencies for project org.geoserver:gs-ows:jar:2.10-SNAPSHOT: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed: Premature end of Content-Length delimited message body (expected: 532393; received: 48484 → [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project gs-ows: Could not resolve dependencies for project org.geoserver:gs-ows:jar:2.10-SNAPSHOT: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed
On Sat, Jun 18, 2016 at 3:19 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Looks like it’s affecting the GeoTools builds too, from the logs of a failed master build, on Ares:
ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geotools: Failed to deploy artifacts: Could not transfer artifact org.geotools:geotools:pom:16-20160618.130816-35 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geotools/geotools/16-SNAPSHOT/geotools-16-20160618.130816-35.pom. Return code is: 500, ReasonPhrase: Internal Server Error. → [Help 1]
On Sat, Jun 18, 2016 at 3:15 PM, Andrea Aime <andrea.aime@anonymised.com268…> wrote:
I was just trying a build with that failed with the following issue:
[ERROR] Failed to execute goal on project gs-netcdf-out: Could not resolve dependencies for project org.geoserver.extension:gs-netcdf-out:jar:2.10-SNAPSHOT: Could not transfer artifact edu.ucar:udunits:jar:4.6.6 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: edu/ucar/udunits/4.6.6/udunits-4.6.6.jar from boundless failed: Premature end of Content-Length delimited message body (expected: 123278; received: 85420 → [Help 1]
I’ve tried to transfer the same jar from a browser, the transfer started but stopped mid air and after a few
minutes the browser gave up and complained
Tried another few times with both Chrome and Firefox, same results.
Also ssh’d into another server and used CURL from the command line, same behavior, the transfer rate
plummets after transferring 80kb and the transfer just ends in the middle:
curl “https://repo.boundlessgeo.com/main/edu/ucar/udunits/4.6.6/udunits-4.6.6.jar” -o /dev/null -D -
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0HTTP/1.1 200 OK
Server: nginx/1.4.6 (Ubuntu)
Date: Sat, 18 Jun 2016 13:14:27 GMT
Content-Type: application/java-archive
Content-Length: 123278
Connection: keep-alive
X-Artifactory-Id: 653349f6e1a12de2:17d92c89:154be413e4d:-8000
Last-Modified: Mon, 13 Jun 2016 21:15:03 GMT
ETag: 753306c362a2a1bf76cfccddeb764b73c2759936
X-Checksum-Sha1: 753306c362a2a1bf76cfccddeb764b73c2759936
Accept-Ranges: bytes
X-Checksum-Md5: 9def2dc675d42622e7b39eed42eb2e5c
X-Artifactory-Filename: udunits-4.6.6.jar
Content-Disposition: attachment; filename=“udunits-4.6.6.jar”; filename*=UTF-8’'udunits-4.6.6.jar
66 120k 66 81324 0 0 1231 0 0:01:40 0:01:06 0:00:34 0
curl: (18) transfer closed with 41954 bytes remaining to read
Looks like some sort of issue in either artifactory or the eventual apache fronting it
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
