Hi Justin, list,
we have some trouble with setting this up, I am posting an e-mail from a colleague below since he is not on the list. TIA for any help.
Hello,
Currently I’m trying to set up Geoserver in 2 JBoss environments reading from the same
data directory. I have the following setup:
Using PostgreSQL 9.0.1 as database, JBoss 4.0.5 GA (2x) each running Geoserver 2.1 beta 2
with the dbconfig plugin (just dumped the jar files into the WEB-INF/lib directory of the
war file). Using 1 single instance of JBoss everything runs smoothly.
Now the idea is to run a second instance of Geoserver pointing to the same datastore. I’m trying
to see if it’s possible that when the configuration of 1 Geoserver instance is updated
(via e.g. GeoCat Bridge) the changes are reflected in the other instances as well.
Unfortunately I get all kinds of error messages starting with the message below:
15:21:55,837 INFO [STDOUT] 14 Dec 15:21:55 ERROR [context.ContextLoader] - Cont
ext initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean wit
h name ‘gwcFacade’ defined in URL [jar:file:/H:/runnableapps/jboss-4.0.5.GA/serv
er/default/./tmp/deploy/tmp1640002882111840325geoserver-exp.war/WEB-INF/lib/gwc-
2.1-beta2.jar!/geowebcache-geoserver-context.xml]: Cannot resolve reference to b
ean ‘gwcTLDispatcher’ while setting constructor argument; nested exception is or
g.springframework.beans.factory.BeanCreationException: Error creating bean with
name ‘gwcTLDispatcher’ defined in URL [jar:file:/H:/runnableapps/jboss-4.0.5.GA/
server/default/./tmp/deploy/tmp1640002882111840325geoserver-exp.war/WEB-INF/lib/
gwc-2.1-beta2.jar!/geowebcache-geoserver-context.xml]: Instantiation of bean fai
led; nested exception is org.springframework.beans.BeanInstantiationException: C
ould not instantiate bean class [org.geowebcache.layer.TileLayerDispatcher]: Con
structor threw exception; nested exception is java.lang.RuntimeException: org.hi
bernate.type.SerializationException: could not deserialize
Now my questions are: is the dbconfig module meant to be used this way? I can’t find
any documentation on this. If it is meant this way, do I need to update specific
settings anywhere to support this?
Thanks in advance for your answer!
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
Bart van den Eijnden
OSGIS
bartvde@anonymised.com
On Dec 9, 2010, at 4:24 PM, Justin Deoliveira wrote:
Hi Rudi,
Actually the module that contains the latest work is called dbconfig [1].
If you are brave and would like to try it out you can grab the latest build from the community nightly builds. [2]. But be warned that it is still not quite stable and is a work in progress. That said it does work and any feedback you could provide as an actual user would be great.
-Justin
[1] http://svn.codehaus.org/geoserver/trunk/src/community/dbconfig/
[2] http://gridlock.opengeo.org/geoserver/trunk/community-latest/
On Thu, Dec 9, 2010 at 7:22 AM, Hochmeister Rudolf <rudolf.hochmeister@anonymised.com> wrote:
Your ‘Geoserver-2.1-beta2 now available’ announcement on [1] drew my attention to database-backed catalog.
I looked into the community[com] module[mod] directory and found ‘hibernate’-mod.
Is this the com-mod that the passage ‘Core improvements to support database-backed catalog’ refers to?
[1] http://blog.geoserver.org/2010/12/06/geoserver-2-1-beta2-now-available/
cheers,
Rudi Hochmeister
Magistrat der Stadt Wien
MA 14 - ADV - Referat EG3
A 1082 Wien, Rathausstraße 1
Email: rudolf.hochmeister@…2581…
Telefon: (+43 1) 4000 91119
Fax: (+43 1) 4000 7141
This SF Dev2Dev email is sponsored by:
WikiLeaks The End of the Free Internet
http://p.sf.net/sfu/therealnews-com
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
