[Geoserver-devel] DataSource Integration
I am looking for technical information on how to integrate a new geospatially enabled relational database with GeoServer. In particular, I’m looking to integrate with Teradata.
I see some very high level deployment related documentation for certain DB platforms but no developer related documentation.
The only relevant thing I found was the following link related to the implementation for MS SQL Server.
http://blog.geoserver.org/2008/11/10/146/
There they make reference to a relational database backed implementation of GeoTools’ data store abstraction.
Some developer-oriented documentation and guidance would be appreciated.
I believe a look at the the source code implementation for one or more of the supported relational database platforms would be a big help.
I’m assuming that they, like GeoServer, are open source projects.
Thanks, in advance, for your assistance.
Kevin Healy
Consulting Manager
Claraview, a division of Teradata
kevin.healy@anonymised.com
703.663.2525 (Office)
540.409.6062 (Wireless)
Challenge Us to Make Business Intelligence WorkSM
Welcome!
The GeoTools library (http://geotools.org/) indeed used, by creating a geotools datastore and packaging it up in a jar you can ask GeoServer to work with your database.
There is a guide for making a datastore using “AbstractDataStore” here:
Since you are using a relational database you will actually want to choose a different base class; there is a “JDBC NG” implementation that serves as the super class for a range of formats; you can base your work on what they do.
Jody
Kevin Healy
Consulting Manager
Geoserver-devel mailing list
