Hello everyone. Recently I updated GS and GT main branches with the latest changes, which include major naming changes for GT. After this update attempting to use mongo schemaless plugin functionality (WFS GetFeature request to schemaless layer) resulted in the error message “Failed to find the datastore factory for Mongo schemaless, did you forget to install the store extension jar?”. The following steps mentioned in GT upgrade page (running ant script) did not resolve the issue. The issue was resolved locally by renaming the file in GS schemaless plugin package META-INF/services folder from org.geotools.data.DataAccessFactory to org.geotools.api.data.DataAccessFactory.
Mykhailo Kotkov
Professional Support for GeoNode, GeoServer and MapStore from the experts!
Visit http://bit.ly/gs-services for more information.
Mykhailo Kotkov
Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
