I have two PostGIS datastores, "store1" and "store2".
store1 is in namespace "ns1" = "http://ns1.example.invalid/"
store2 is in namespace "ns1" = "http://ns2.example.invalid/"
Both datastores have a table called "features".
I have two feature types "ns1:features" and "ns2:features".
Both have a schema with in it the (GeoServer-generated) complexType with
name "features_Type".
If I try to store a feature in ns1:features I get an error message from
GeoServer that some attribute that only exists in ns1:features is not
found:
26-Jul-2007 14:56:10 org.vfny.geoserver.servlets.AbstractService sendError
SEVERE: Service exception occurred
org.vfny.geoserver.wfs.responses.WfsTransactionException: org.xml.sax.SAXException: Could not find attributeType named featureNamein featureType DefaultFeatureType [name=features , namespace=http://ns2.example.invalid/ , abstract=false , types=(...list of all attributes in wrong featureType deleted...)]
[the missing space between the attribute type "featureName" and "in" is
GeoServer's BTW]
Complete stack trace attached. This is with the GeoServer-1.5.x nightly
from June 21st.
The WFS transaction that tries to store the feature has the correct
namespaces and everything:
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0"><wfs:Insert><ns1:features xmlns:ns1="http://ns1.example.invalid/"><ns1:featureName>test</ns1:featureName>\.\.\.etc\.\.\.</ns1:features></wfs:Insert></wfs:Transaction>
If I remove the featureType ns2:features from my config the store succeeds.
-- Gertjan van Oosten, gertjan@anonymised.com, West Consulting B.V., +31 15 2191 600
(attachments)
geoserver-trace.txt (8.69 KB)
I will look into this.. Just for the sake of completeness could include the structure of the two tables. Thanks.
-Justin
found:
GeoServer's BTW]
from June 21st.
!DSPAM:4007,46a8ba9e5581439371379!
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
As quoted from Justin Deoliveira <jdeolive@anonymised.com>:
> found:
> GeoServer's BTW]
> from June 21st.
Here you go:
store1=# \d features
Table "public.features"
Column | Type | Modifiers
oid | integer | not null default nextval('features_oid_seq'::regclass)
featureName| character varying | not null
width | double precision | not null
height | double precision | not null
geom | geometry | not null
timestamp | timestamp with time zone | not null
Indexes:
"features_pkey" PRIMARY KEY, btree (oid)
Check constraints:
"enforce_dims_geom" CHECK (ndims(geom) = 2)
"enforce_geotype_geom" CHECK (geometrytype(geom) = 'POINT'::text OR geom IS NULL)
"enforce_srid_geom" CHECK (srid(geom) = 4326)
store2=# \d features
name | character varying |
type | character varying |
time | timestamp with time zone |
geometry | geometry |
Indexes:
Check constraints:
"enforce_dims_geometry" CHECK (ndims(geometry) = 2)
"enforce_geotype_geometry" CHECK (geometrytype(geometry) = 'POINT'::text OR geometry IS NULL)
"enforce_srid_geometry" CHECK (srid(geometry) = 4326)
Hmm... I don't see a jira issue open for this... fear we're going to forget it?
Its sitting on my todo list of things to look at... after i verified it i was going to start the jira task... perhaps we should just create the task anyways.
-Justin
!DSPAM:4007,46ad92b3106641030819293!
Justin Deoliveira
Ok.. so i tried to replicate this but could not. I followed the steps provided by Gertjan and the insert succeeded no problem. Andrea perhaps you can be the tie breaker and try it out.
-Justin
Justin Deoliveira
Yeah, I managed to reproduce it, and hopefully fixed it.
Gertjan, can you try out the July 31 nightly (when it's ready) from
http://geo.openplans.org/nightly/1.5.x/ and tell me if things work
for you?
Hi Andrea,
Sorry for the delay, I was frantically busy.
As quoted from Andrea Aime <aaime@anonymised.com>:
for you?
I tried it, and it does indeed work. Thanks Andrea!
By the way, it does log an (unrelated) error:
03-Aug-2007 08:52:31 org.geotools.util.CommonHandler publish
SEVERE: There's code leaving readers or writers unclosed (you got an unclosed QueryData object, which is usually held by a reader or a writer).
Call reader/writer.close() after using them to ensure they do not hold state such as JDCB connections.
QueryData was open against feature type: features
[Also mind the typo "JDCB" -> "JDBC"]
Kind regards,
Gertjan van Oosten ha scritto:
Hi Andrea,
for you?
My pleasure.
Triple bah, this is bad, bad, bad. It means some JDBC connections are temporarily lost from the pool (the code in the finalizer closes them
when garbage collection is run, but this is unpredictable).
Can you tell me what were you doing when that error appeared?
I can't for the life of me figure it out; no matter what I try, I can't
reproduce it. Weird huh? If I see it again, I'll try to pay more
attention to what I was doing...
Kind regards,
