[Geoserver-devel] Datestamped GeoTools artifacts from opengeo repo while building GeoServer?
I build my own local GeoTools trunk and then build GeoServer trunk. Recently I noticed that, while building GeoServer, maven downloads what look like datestamped GeoTools snapshot artifacts, even though, as far as I know, I do not need them to build GeoServer trunk, which depends on GeoTools artifacts 2.6-SNAPSHOT. For example:
Downloading: http://repo.opengeo.org//org/geotools/gt-main/2.6-SNAPSHOT/gt-main-2.6-20090325.063156-27.jar
1159K downloaded
Because I am building my own GeoTools trunk artifacts (2.6-SNAPSHOT) and have installed these fresh jars in my local repository, I do not need nor did I expect to download GeoTools artifacts from the maven repositories. All my Eclipse dependencies are on non-datestamped artifacts, for example:
M2_REPO/org/geotools/gt-main/2.6-SNAPSHOT/gt-main-2.6-SNAPSHOT.jar
Could someone please explain to me:
(1) Why is maven getting GeoTools artifacts that are not a dependency of the GeoServer projects that I am building? Is it because they are installed in the 2.6-SNAPSHOT directory on the remote repo?
(2) Who is installing these artifacts, and why?
(3) Is this a correct use of the maven repository structure?
Downloading these unnecessary artifacts slows my build process, and wastes network and disk resources. I got one batch for the 24th, now one for the 25th. Where does it end?
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
The joys of maven :). Trust me, I feel your pain.
That said, something seems a miss. If you build geotools locally and then build geoserver there should be no external downloads... there should only be a check of the timestamps, in which it should find your local copy newer and prevent the download.
I do this more or less daily to try avoid the downloads like you are doing, and it always work. I actually build offline (-o) just to make sure i don't get any downloads. So something must be off.
I am curious, when does the geotools main dependency get dragged in and downloaded? At which module?
Some additional comments inline.
1159K downloaded
We have a nightly script that does this so that people don't have to check out and build geotools to build geoserver. One thing you can do to avoid downloading is just comment out the opengeo repository from the root geoserver pom of your checkout. Or use settings.xml to override it.
Yup, afaik. WE just run mvn deploy:deploy and it handles creating the proper repository structure.
Kind regards,
Justin Deoliveira
OpenGeo - http://opengeo.org
That is my understanding. Until today. :expressionless:
That is a pain. I want to make sure I have up-to-date dependencies.
Looks like it.
If those are meant to be UTC timestamps after the date, they are in the future. Would maven honour an artifact that claimed to be from the future, and thus authoritative over locally built and correctly timestamped artifacts? My local GeoServer build was at around 05:15 UTC, and the artifacts downloaded at this time appear be stamped after 06:30 UTC.
The metadata suggests that the trailing digits are HHMMSS. Are they UTC?
http://repo.opengeo.org//org/geotools/gt-main/2.6-SNAPSHOT/maven-metadata.xml
Do we have a rogue build box that is claiming to be from the future?
All of them. I get a snapshot downloaded for every GeoTools artifact. And I just realised that the downloaded jar is copied over my local gt-whatever-2.6-SNAPSHOT.jar, so I lose all my local changes.
Who manages the machine that builds and deploys?
Kind regards,
1159K downloaded
Today my GeoServer build worked fine and honoured my locally built GeoTools artifacts. It did not download any of the daily snapshots. Whatever was causing my problem has gone away ...
1159K downloaded
Perhaps it is working because no GeoTools snapshot was built overnight?
1159K downloaded
This problem still exists. I think the timestamps are wrong. These problems occur after noon my time.
The snapshots have a local timestamp of 11pm. 11pm EDT = 3am UTC (assuming this machine honours daylight saving.) However the maven metadata marks these as being updated at 6:30am UTC, 3 and a half hours in the future. The files are uploaded at about noon my time, so if at any time in the next three and a half hours I make a local GeoTools build, when I run GeoServer the older snapshots on the remote repo will claim to be newer.
- Could I be right?
- Who is responsible for timestamping these snapshots?
- Where do I lodge a Jira issue?
Kind regards,
Lodge to geotools; sounds like a server is configured incorrectly.
Boy maven does bring home the complications of international development.
Jody
On Fri, Mar 27, 2009 at 3:52 PM, Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com wrote:
Downloading:
1159K downloaded
Whatever was causing my problem has gone away …
claim to be newer.
  • Could I be right?
  • Who is responsible for timestamping these snapshots?
  • Where do I lodge a Jira issue?
Kind regards,
Geotools-devel mailing list
Geotools-devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
I just logged in our Hudson/nightly build box and I can confirm
there is a problem. Now in Italy it's 8:36am, meaning the NY time
is 3.36am, yet gridlock.openplans.org reports:
[aaime@anonymised.com ~]$ date --utc
Fri Mar 27 11:17:18 UTC 2009
Fri Mar 27 07:17:23 EDT 2009
So it seems to be roughly 4 hours in the future.
I don't know how the machine is setup, if the time is manually
set or if there is a connection with a rogue NTP server somewhere,
so I'll just pass down the info to the admins in NY when they
get around.
I'll let you know.
Andrea Aime
Arne, did you fix this? I just logged into gridlock and the time seems ok to me.
get around.
I'll let you know.
Justin Deoliveira
Yeah, Arne fixed it. I wanted to reply to this thread but I thought
to let some hours pass to make sure the clock did not go
bye bye again. As you just confirmed, it didn't :slight_smile:
Andrea Aime
Thanks!
