[Geoserver-devel] DDS module trouble
looking at the pull requests opened against GeoServer, we can see there
is clear interest in the DDS module:
https://github.com/geoserver/geoserver/pull/517
https://github.com/geoserver/geoserver/pull/590 (this one lacks a contribution agreement too)
https://github.com/geoserver/geoserver/pull/616
Unfortunately, the module is not building on trunk, some of the pull requests
make more tests fail, and I have no idea whether they are intersecting
each other or not.
I believe we need someone to look into it and fix things so that
the contributions can go in.
Is there any taker?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Sun, Oct 5, 2014 at 11:06 AM, Andrea Aime <andrea.aime@anonymised.com>
This one is not about dds, but about w3ds, confusion on my part, sorry.
The other two are though
Ing. Andrea Aime
@geowolf
Technical Lead
I've fixed the tests that fail when building on trunk (I believe this will fix the failing tests in pull/616, but haven't confirmed). I'm waiting on a contribution agreement from my employer. I'll submit a pull request today, and remind my manager that I need the contribution paperwork.
I'm willing to put in some work to sort out the issues, but I'm also starting a new job next week, so my availability is limited.
Parker
On 10/5/14, 2:06 AM, Andrea Aime wrote:
each other or not.
Is there any taker?
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Sun, Oct 5, 2014 at 7:29 PM, Parker Abercrombie <
Excellent, that's great. You changed a single file, a test, so for this one
we don't need a contribution agreement, but having one
will definitely make things easier in the future.
Pull request merged
That's very nice of you, any help is certainly welcomed!
Ing. Andrea Aime
@geowolf
Technical Lead
